Optimized for safeguarding essential data while on-the-go, the ThinkPad USB 3.0 1TB Secure Hard Drive offers high-level 256-bit Advanced Encryption Standard (AES) security within a slim, lightweight, self-powered, easy-to-use design.- Connectivity via either USB 2.0 or USB 3.0 (2) interface
- Compact size
- No requirement for an ac power adapter
- Driverless operation under Microsoft Windows 7, Windows XP and Vista
- All stored data is fully encrypted using the AES 256-bit security encryption algorithm
- Real-time encryption with no read/write speed impact
- Shock-mounted 1TB 5400 rpm hard drive capacity
- Built-in USB 3.0 cable with an integral storage slot
- Integrated high quality metal dome switch keypad for entering an 8 to 16 digit password for 1 user ID and 1 administrator ID
- USB Y extension cable to ensure adequate power
- Attractive protective carrying case
- Non-skid anti-vibration pads
- High quality ThinkPad soft touch paint
- Multi-colored LED device status indicator
The ThinkPad USB 3.0 1TB Secure Hard Drive option also enables
- Easy and secure storage expansion
- No software installation and no power adapter required for operation
- Built-in administrative password management
- Simple file backup
- Lenovo ThinkPad USB 3.0 Secure - hard drive - 1 TB - USB 3.0 - CRU
- Hard drive - external (portable)
- Capacity
- 1 TB
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Spindle Speed
- 5400 rpm
- Shock resistant, built-in keypad, password authentication, 256-bit AES
- Power Source
- USB bus
- 8.69 cm x 12.203 cm x 1.925 cm
- 216 g
- Pricing Type
- Customer-replaceable Unit (CRU)
- 3-year warranty
- Designed For
- 100e Chromebook (2nd Gen) MTK.2; 100e Chromebook Gen 3; 14e Chromebook Gen 2; 500e Chromebook Gen 3; IdeaPad 1 14; 1 15; 3 14; 3 15; 3 15IGL05; 3 15IML05; IdeaPad Gaming 3 15; K14 Gen 1; ThinkCentre M70a Gen 2; M70q Gen 2; M70q Gen 3; M70s Gen 3; M70t Gen 3; M75; M75q Gen 2; M75s Gen 2; M75t Gen 2; M80q Gen 3; M90; M90a Gen 2; M90q Gen 2; M90q Gen 3; ThinkCentre neo 30a 24; 50; ThinkEdge SE30; ThinkPad E14 Gen 3; L13 Gen 2; L13 Gen 3; L13 Yoga Gen 2; L13 Yoga Gen 3; P1 Gen 4; P1 Gen 5; P14s Gen 3; P15v Gen 2; T14 Gen 2; T14s Gen 2; T14s Gen 3; T15p Gen 2; X1 Carbon Gen 10; X1 Extreme Gen 4; X1 Yoga Gen 7; X13 Gen 2; ThinkStation P340; V50a-24IMB AIO; V50s-07; V50t Gen 2-13; Yoga 6 13
- Capacity
- 1 TB
- Interface
- USB 3.0
- 8.69 cm
- 12.203 cm
- 1.925 cm
- 216 g
Performance
- Interface Transfer Rate
- Max Data Transfer Rate
- 75 MB/s
- Data Transfer Rate Details
- USB 3.0 (read): 75 MB/s ¦ USB 3.0 (write): 55 MB/s ¦ USB 2.0 (read): 33 MB/s ¦ USB 2.0 (write): 25 MB/s
- Spindle Speed
- 5400 rpm
Expansion & Connectivity
- 1 x USB 3.0
- Power Source
- USB bus
- OS Required
- Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
- Included Accessories
- Carrying case
- Cables Included
- 1 x USB cable - integrated ¦ 1 x USB extension cable - external
- UL, VCCI, C-Tick, BSMI, cUL, FCC, ICES
- Pricing Type
- Limited warranty - 3 years
- 5 °C
- 55 °C
- 5 - 95%
- Designed For
- Lenovo 100e Chromebook (2nd Gen) MTK.2 82Q3 ¦ Lenovo 100e Chromebook Gen 3 82J7, 82J8 ¦ Lenovo 14e Chromebook Gen 2 82M1 ¦ Lenovo 500e Chromebook Gen 3 82JB, 82JC ¦ Lenovo IdeaPad 1 14ALC7 82R3 ¦ Lenovo IdeaPad 1 15ALC7 82R4 ¦ Lenovo IdeaPad 3 14ABA7 82RM ¦ Lenovo IdeaPad 3 15ABA7 82RN ¦ Lenovo IdeaPad 3 15IGL05 82BU ¦ Lenovo IdeaPad 3 15IML05 82BS ¦ Lenovo IdeaPad Gaming 3 15IAH7 82S9 ¦ Lenovo K14 Gen 1 21CU ¦ Lenovo ThinkCentre M70a Gen 2 11K3, 11K4 ¦ Lenovo ThinkCentre M70q Gen 2 11N0, 11N3, 11N4 ¦ Lenovo ThinkCentre M70q Gen 3 11T3, 11T4 ¦ Lenovo ThinkCentre M70s Gen 3 11T7, 11T8, 11TB ¦ Lenovo ThinkCentre M70t Gen 3 11T5, 11T6 ¦ Lenovo ThinkCentre M75n 11BU, 11BV ¦ Lenovo ThinkCentre M75q Gen 2 11JN, 11JQ, 11JS ¦ Lenovo ThinkCentre M75s Gen 2 11W1, 11W2, 11W4 ¦ Lenovo ThinkCentre M75t Gen 2 11KE, 11W6 ¦ Lenovo ThinkCentre M80q Gen 3 11U1 ¦ Lenovo ThinkCentre M90a Gen 2 11JY, 11K0, 11K1 ¦ Lenovo ThinkCentre M90q 11DK, 11F0 ¦ Lenovo ThinkCentre M90q Gen 2 11MR, 11MV ¦ Lenovo ThinkCentre M90q Gen 3 11U5, 11U8 ¦ Lenovo ThinkCentre neo 30a 24 12B0 ¦ Lenovo ThinkCentre neo 50t 11SC, 11SE ¦ Lenovo ThinkEdge SE30 11NC, 11NJ ¦ Lenovo ThinkPad E14 Gen 3 20YD, 20YF ¦ Lenovo ThinkPad L13 Gen 2 21AB, 21AC ¦ Lenovo ThinkPad L13 Gen 3 21B9 ¦ Lenovo ThinkPad L13 Yoga Gen 2 21AD, 21AE ¦ Lenovo ThinkPad L13 Yoga Gen 3 21BB ¦ Lenovo ThinkPad P1 Gen 4 20Y4 ¦ Lenovo ThinkPad P1 Gen 5 21DC ¦ Lenovo ThinkPad P14s Gen 3 21AK ¦ Lenovo ThinkPad P15v Gen 2 21A9, 21AA ¦ Lenovo ThinkPad T14 Gen 2 20XK ¦ Lenovo ThinkPad T14s Gen 2 20XF, 20XG ¦ Lenovo ThinkPad T14s Gen 3 21BR, 21BS ¦ Lenovo ThinkPad T15p Gen 2 21A8 ¦ Lenovo ThinkPad X1 Carbon Gen 10 21CB, 21CC ¦ Lenovo ThinkPad X1 Extreme Gen 4 20Y5, 20Y6 ¦ Lenovo ThinkPad X1 Yoga Gen 7 21CD, 21CE ¦ Lenovo ThinkPad X13 Gen 2 20XH, 20XJ ¦ Lenovo ThinkStation P340 30DU ¦ Lenovo V50a-24IMB AIO 11FK ¦ Lenovo V50s-07IMB 11HA ¦ Lenovo V50t Gen 2-13IOB 11QB, 11QC ¦ Lenovo Yoga 6 13ALC7 82UD
