Optimized for safeguarding essential data while on-the-go, the ThinkPad USB 3.0 1TB Secure Hard Drive offers high-level 256-bit Advanced Encryption Standard (AES) security within a slim, lightweight, self-powered, easy-to-use design.- Connectivity via either USB 2.0 or USB 3.0 (2) interface
- Compact size
- No requirement for an ac power adapter
- Driverless operation under Microsoft Windows 7, Windows XP and Vista
- All stored data is fully encrypted using the AES 256-bit security encryption algorithm
- Real-time encryption with no read/write speed impact
- Shock-mounted 1TB 5400 rpm hard drive capacity
- Built-in USB 3.0 cable with an integral storage slot
- Integrated high quality metal dome switch keypad for entering an 8 to 16 digit password for 1 user ID and 1 administrator ID
- USB Y extension cable to ensure adequate power
- Attractive protective carrying case
- Non-skid anti-vibration pads
- High quality ThinkPad soft touch paint
- Multi-colored LED device status indicator
The ThinkPad USB 3.0 1TB Secure Hard Drive option also enables
- Easy and secure storage expansion
- No software installation and no power adapter required for operation
- Built-in administrative password management
- Simple file backup
- Lenovo ThinkPad USB 3.0 Secure - hard drive - 1 TB - USB 3.0 - CRU
- Hard drive - external (portable)
- Capacity
- 1 TB
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Spindle Speed
- 5400 rpm
- Shock resistant, built-in keypad, password authentication, 256-bit AES
- Power Source
- USB bus
- 8.69 cm x 12.203 cm x 1.925 cm
- 216 g
- Pricing Type
- Customer-replaceable Unit (CRU)
- 3-year warranty
- Designed For
- 100e Chromebook (2nd Gen) MTK.2; IdeaPad 1 14; 1 15; 3 14; 3 15; 3 15IML05; IdeaPad Gaming 3 15; IdeaPad S340-14; K14 Gen 1; ThinkCentre M70a Gen 2; M70q Gen 2; M70q Gen 3; M70s Gen 3; M70t Gen 3; M75; M75q Gen 2; M75s Gen 2; M75t Gen 2; M80q Gen 3; M80s Gen 3; M80t Gen 3; M90; M90a Gen 2; M90a Gen 3; M90q Gen 2; M90q Gen 3; M90s Gen 3; M90t Gen 3; ThinkCentre neo 30a 22; 30a 24; 50; ThinkEdge SE30; ThinkPad E14 Gen 3; E14 Gen 4; E15 Gen 4; L13 Gen 2; L13 Gen 3; L13 Yoga Gen 3; P1 Gen 5; P14s Gen 3; P15v Gen 3; T14 Gen 3; T14s Gen 2; T14s Gen 3; T15p Gen 2; T15p Gen 3; T16 Gen 1; X1 Carbon Gen 10; X1 Yoga Gen 7; X13 Gen 2; ThinkStation P340; V50a-24IMB AIO; V50t Gen 2-13; Yoga 6 13
- Capacity
- 1 TB
- Interface
- USB 3.0
- 8.69 cm
- 12.203 cm
- 1.925 cm
- 216 g
Performance
- Interface Transfer Rate
- Max Data Transfer Rate
- 75 MB/s
- Data Transfer Rate Details
- USB 3.0 (read): 75 MB/s , USB 3.0 (write): 55 MB/s , USB 2.0 (read): 33 MB/s , USB 2.0 (write): 25 MB/s
- Spindle Speed
- 5400 rpm
Expansion & Connectivity
- 1 x USB 3.0
- Power Source
- USB bus
- OS Required
- Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
- Included Accessories
- Carrying case
- Cables Included
- 1 x USB cable - integrated , 1 x USB extension cable - external
- UL, VCCI, C-Tick, BSMI, cUL, FCC, ICES
- Pricing Type
- Limited warranty - 3 years
- 5 °C
- 55 °C
- 5 - 95%
- Designed For
- Lenovo 100e Chromebook (2nd Gen) MTK.2 82Q3 , Lenovo IdeaPad 1 14ALC7 82R3 , Lenovo IdeaPad 1 15ALC7 82R4 , Lenovo IdeaPad 3 14ABA7 82RM , Lenovo IdeaPad 3 15ABA7 82RN , Lenovo IdeaPad 3 15IML05 82BS , Lenovo IdeaPad Gaming 3 15IAH7 82S9 , Lenovo IdeaPad S340-14IILD 81WJ , Lenovo K14 Gen 1 21CU , Lenovo ThinkCentre M70a Gen 2 11K4 , Lenovo ThinkCentre M70q Gen 2 11N3 , Lenovo ThinkCentre M70q Gen 3 11T3, 11T4 , Lenovo ThinkCentre M70s Gen 3 11T7, 11T8, 11TB , Lenovo ThinkCentre M70t Gen 3 11T5, 11T6 , Lenovo ThinkCentre M75n 11BU, 11BV , Lenovo ThinkCentre M75q Gen 2 11JN, 11JQ, 11JS , Lenovo ThinkCentre M75s Gen 2 11W1, 11W2, 11W4 , Lenovo ThinkCentre M75t Gen 2 11KE, 11W6 , Lenovo ThinkCentre M80q Gen 3 11U1 , Lenovo ThinkCentre M80s Gen 3 11TG, 11TL , Lenovo ThinkCentre M80t Gen 3 11TE, 11TJ , Lenovo ThinkCentre M90a Gen 2 11K0, 11K1 , Lenovo ThinkCentre M90a Gen 3 11VF, 11VH , Lenovo ThinkCentre M90q 11DK , Lenovo ThinkCentre M90q Gen 2 11MR, 11MV , Lenovo ThinkCentre M90q Gen 3 11U5, 11U8 , Lenovo ThinkCentre M90s Gen 3 11TT, 11TX , Lenovo ThinkCentre M90t Gen 3 11TM, 11TN, 11TV , Lenovo ThinkCentre neo 30a 22 12B1 , Lenovo ThinkCentre neo 30a 24 12B0 , Lenovo ThinkCentre neo 50t 11SC, 11SE, 11SF , Lenovo ThinkEdge SE30 11NJ , Lenovo ThinkPad E14 Gen 3 20YF , Lenovo ThinkPad E14 Gen 4 21E3 , Lenovo ThinkPad E15 Gen 4 21E6 , Lenovo ThinkPad L13 Gen 3 21B9 , Lenovo ThinkPad L13 Yoga Gen 3 21BB , Lenovo ThinkPad P1 Gen 5 21DC , Lenovo ThinkPad P14s Gen 3 21AK , Lenovo ThinkPad P15v Gen 3 21D8, 21D9 , Lenovo ThinkPad T14 Gen 3 21AH , Lenovo ThinkPad T14s Gen 2 20XF , Lenovo ThinkPad T14s Gen 3 21BR, 21BS , Lenovo ThinkPad T15p Gen 2 21A8 , Lenovo ThinkPad T15p Gen 3 21DA , Lenovo ThinkPad T16 Gen 1 21BV , Lenovo ThinkPad X1 Carbon Gen 10 21CB, 21CC , Lenovo ThinkPad X1 Yoga Gen 7 21CD, 21CE , Lenovo ThinkStation P340 30DU , Lenovo V50a-24IMB AIO 11FK , Lenovo V50t Gen 2-13IOB 11QB, 11QC , Lenovo Yoga 6 13ALC7 82UD
