Lenovo 19" Wide L197p 5ms DVI LCD TFT
Quicklinx: 553LWS00 Mfr#: T44HNUK
The Lenovo ThinkVision L197 widescreen monitor provides an excellent viewing experience. The L197 offers digital visual interface (DVI) connectivity with high-bandwidth digital copy protection (HDCP) to deliver high-definition viewing of protected contents. The widescreen monitor improves efficiency with easy viewing of multiple applications.
The L197 with an EPEAT gold rating meets the criteria for the highest rating in environmental performance. This monitor coordinates with the Think family design for use with any Lenovo ThinkCentre or ThinkPad system, making it the ideal choice to replace the 17-inch LCD monitor.
This monitor is best suited for complex spreadsheets, multitasking, general business applications, multiple-monitor environments.
  • Wide viewing angles
    With horizontal and vertical viewing angles of 176 degrees, the Lenovo ThinkVision L197 offers a comfortable viewing experience from a variety of positions, making it ideal for collaborative work.
  • Energy efficient
    Certified by ENERGY STAR and EPEAT Gold, this monitor is designed for energy efficiency, reducing power consumption in both operational and standby modes to only 22 W and 2 W respectively.
  • High image quality
    The monitor boasts a 19-inch widescreen display with a native resolution of 1440 x 900, providing clear and vibrant visuals. A high contrast ratio of 1000:1 and brightness level of 250 cd/m2 ensure that images are sharp and detailed.
  • Versatile connectivity
    Equipped with both DVI and VGA interfaces, the Lenovo ThinkVision L197 allows for flexible connectivity options to a wide range of devices.
  • Ergonomic design
    Featuring tilt adjustments and a wall-mountable design, this monitor can be easily adjusted to suit your workspace, ensuring comfort during long working hours.
Lenovo ThinkVision L197 - LCD monitor - 19" - TopSeller
LCD monitor - 19"
Aspect Ratio
16:10
Native Resolution
1440 x 900 at 75 Hz
Pixel Pitch
0.285 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, anti-reflective
Voltage
Business black
44 cm x 17.9 cm x 38.1 cm
4.2 kg
English / United Kingdom
Manufacturer Selling Program
TopSeller
Microsoft Certification
Certified for Windows Vista
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
FCC Class B certified, MPR II, CSA, UL, TUV, BSMI, VCCI Class B ITE, GOST, DEMKO, FIMKO, GS, IEC950, ISO 13406-2, NEMKO, NOM, SASO, SEMKO, TUV S, VESA DPMS, CCC, IC, PSB, MIC, RoHS, WEEE, JEITA
3-year warranty
Display Type
LCD monitor / TFT active matrix
Diagonal Size
19"
Aspect Ratio
16:10
Native Resolution
1440 x 900 at 75 Hz
Pixel Pitch
0.285 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Vertical Refresh Rate
76 Hz
Horizontal Refresh Rate
81 kHz
Video Bandwidth
137 MHz
Horizontal Viewing Angle
176
Vertical Viewing Angle
176
Screen Coating
Controls & Adjustments
Brightness, contrast, H/V position, input select
OSD Languages
English, German, French, Italian, Spanish, Japanese, Chinese
HDCP
Business black
4.2 kg
1 x DVI-D - 24+1 pin digital DVI , 1 x VGA - 15 pin HD D-Sub (HD-15)
Mechanical
Tilt
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable
1 x DVI cable - 1.8 m , 1 x VGA cable - 1.8 m
Mounting Kit
Optional
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
TopSeller
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
22 Watt
Power Consumption Stand by / Sleep
2 Watt
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - replacement - 3 years - carry-in
45 °C
10 - 80%
Resources
The following resources are available for the Lenovo 19" Wide L197p 5ms DVI LCD TFT
