Lenovo 16GB TruDDR4 Memory (2Rx4, 1.2V) PC4-17000 CL15 2133MHz LP R
Quicklinx: BZWPWS00 Mfr#: 46W0796
Boost the capabilities of your server and keep it performing reliably with IBM memory. Upgrading your memory is a cost-effective way to improve system performance when insufficient memory and hard drive paging is slowing your applications down.
  • Faster start-up times with fewer delays during routine operations.
  • More programs running simultaneously.
  • Easy toggling between several open applications.
  • Rigorous supplier qualification processes for ensured quality.
  • Enhanced compatibility
    Designed specifically for system upgrades, the Lenovo TruDDR4 memory module ensures seamless integration with your existing setup, providing a reliable and cost-effective way to enhance your system's performance without compatibility issues.
  • Energy efficient
    Operating at a low supply voltage of 1.2 V, this memory module not only delivers on performance but also significantly reduces energy consumption, making it an ideal choice for environmentally conscious users looking to optimize their system's energy efficiency.
Lenovo TruDDR4 - DDR4 - module - 16 GB - DIMM 288-pin - 2133 MHz / PC4-17000 - registered
Memory module
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15
Dual rank, registered
Voltage
1.2 V
IBM 46W0796
1-year warranty
System x3550 M5 5463; x3650 M5 5462; x3850 X6 6241; x3950 X6 6241
16 GB
Upgrade Type
System specific
IBM 46W0796
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL15
ECC
Chips Organization
X4
Voltage
1.2 V
1-year warranty
Lenovo System x3550 M5 5463 , Lenovo System x3650 M5 5462 , Lenovo System x3850 X6 6241 , Lenovo System x3950 X6 6241
