Meet the Lenovo 14e Chromebook, a powerful, versatile Chromebook with high-performance processing. The possibilities it gives to students, teachers, and businesses are endless.
Performance you can count on
With AMD A4 dual-core processing and the Chrome OS, everything runs smoothly on the Lenovo 14e Chromebook. You can also choose from thousands of education and business apps on Google Play and in the Chrome Web Store, including TinkerCAD, Expensify, LucidChart, and Dropbox. -
Multitask with ease
Open as many windows as you like. Run multiple apps. Play high-definition videos. Or stream your favorite TV shows. Whatever task you want to do, the 14e Chromebook will perform smoothly-without compromising a thing. -
From the classroom to the boardroom
Fast and secure, Chromebooks require little-to-no maintenance, boot up in seconds, and can run all day. Factor in the automatic updates, built-in flexibility, and an affordable price tag, and you can see why Chromebooks are now the go-to device for many schools, as well as businesses of all sizes. -
Easy on the eyes
Behind the stamped aluminum shell cover, the 14" FHD display boasts a 6 mm narrow bezel, plus IPS and antiglare technology. The result is a larger, more vibrant screen with wide-angle viewing that's less of a strain on your eyes. There's also a touchscreen option for faster, more intuitive interaction. -
No more crying over spilled coffee
The full-sized keyboard includes a sealed touchpad that can resist spills of up to 1.39 cups (330 ml). It also boasts mechanically anchored keys that stay put regardless of the bumps and knocks of daily life. Available with backlit keys, too. -
Bringing people& ideas closer
The front-facing 720p HD camera comes with two microphones, making videoconferencing or chatting over Google Hangouts a breeze. What's more, everything sounds and looks crystal clear, enabling closer collaboration-even from across the globe. -
Chromebook unplugged
Fully charged, the 14e Chromebook can run for up to 13 hours. That's more than enough juice to entertain you on your daily commute and get things done when you're at school or work. At home, simply recharge your Chromebook overnight and it's good to go the next day.
- Lenovo 14e Chromebook - 14" - AMD A4 - 9120C - 4 GB RAM - 32 GB eMMC - UK
- Product Type
- Chromebook
- Operating System
- Chrome OS - English
- Processor
- AMD A4 9120C / 1.6 GHz (2.4 GHz) / 1 MB Cache
- Memory
- 4 GB DDR4 (provided memory is soldered)
- Storage
- 32 GB eMMC
- Display
- 14" LED backlight 1920 x 1080 / Full HD
- Graphics
- AMD Radeon R4
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Battery
- Up to 10 hours
- Mineral grey
- 32.8 cm x 22.5 cm x 1.77 cm
- 1.48 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- SAR
- 0.38 W/kg (body), 0.38 W/kg (limb)
- Limited warranty - 1 year - pick-up and return
- Product Type
- Chromebook
- Operating System
- Google Chrome OS - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.4 GHz
- Number of Cores
- Dual-Core
- Cache
- L2 - 1 MB
- 64-bit Computing
- RAM
- 4 GB (provided memory is soldered)
- Technology
- DDR4 SDRAM
- Speed
- 1666 MHz
Storage
- Main Storage
- 32 GB eMMC - eMMC 5.1
Display
- 14"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 220 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- AMD Radeon R4
- Camera
- Yes - 720p
- Sound
- Stereo speakers, dual array microphone
- Codec
- DA7219
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Spill-resistant, buttonless touchpad, anti-pry key caps
Communications
- Wireless
- Wireless Controller
- M.2 Card
- Technology
- Lithium Ion
- Capacity
- 57 Wh
- Run Time
- Up to 10 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt
Connections & Expansion
- 2 x USB 3.0 , 2 x USB-C 3.0 , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSD)
- Mineral grey
- Case Material
- Polycarbonate ABS
- Google H1 security chip
- Theft/Intrusion Protection
- Included Accessories
- USB-C power adapter
- RoHS, MIL-STD 810G
- SAR Value
- Localization
- 1.48 kg
Sustainability Information
- ENERGY STAR Certified
Essential Accessories (3)
Get more from your purchase from one of our essential accessories
Lenovo 45W Standard AC Adapter (USB Type-C) Power Adapter | In Stock | £26.01 |
Lenovo 65W Standard AC Adapter USB-C | In Stock | £29.56 |
Lenovo USB-C 65W AC Adapter AC 100-240 V 65Watt for ThinkPad A275 | In Stock | £29.56 |
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
Lenovo 3Y On Site Warratny | In Stock | £45.90 |
Other bundles (3)
Lenovo Professional Wireless Keyboard | In Stock | £53.21 |
Lenovo ThinkPad USB3.0 to Ethernet Adapter | In Stock | £16.07 |
Lenovo Essential Wired Keyboard and Mouse Combo - UK English | In Stock | £25.39 |
