Lenovo 14e Chromebook AMD A4-9120C 4GB 32GB 14"
Quicklinx: FFVMWS00 Mfr#: 81MH0000UK
  • IEEE 802.11n
Meet the Lenovo 14e Chromebook, a powerful, versatile Chromebook with high-performance processing. The possibilities it gives to students, teachers, and businesses are endless.
  • Performance you can count on
    With AMD A4 dual-core processing and the Chrome OS, everything runs smoothly on the Lenovo 14e Chromebook. You can also choose from thousands of education and business apps on Google Play and in the Chrome Web Store, including TinkerCAD, Expensify, LucidChart, and Dropbox.
  • Multitask with ease
    Open as many windows as you like. Run multiple apps. Play high-definition videos. Or stream your favorite TV shows. Whatever task you want to do, the 14e Chromebook will perform smoothly-without compromising a thing.
  • From the classroom to the boardroom
    Fast and secure, Chromebooks require little-to-no maintenance, boot up in seconds, and can run all day. Factor in the automatic updates, built-in flexibility, and an affordable price tag, and you can see why Chromebooks are now the go-to device for many schools, as well as businesses of all sizes.
  • Easy on the eyes
    Behind the stamped aluminum shell cover, the 14" FHD display boasts a 6 mm narrow bezel, plus IPS and antiglare technology. The result is a larger, more vibrant screen with wide-angle viewing that's less of a strain on your eyes. There's also a touchscreen option for faster, more intuitive interaction.
  • No more crying over spilled coffee
    The full-sized keyboard includes a sealed touchpad that can resist spills of up to 1.39 cups (330 ml). It also boasts mechanically anchored keys that stay put regardless of the bumps and knocks of daily life. Available with backlit keys, too.
  • Bringing people& ideas closer
    The front-facing 720p HD camera comes with two microphones, making videoconferencing or chatting over Google Hangouts a breeze. What's more, everything sounds and looks crystal clear, enabling closer collaboration-even from across the globe.
  • Chromebook unplugged
    Fully charged, the 14e Chromebook can run for up to 13 hours. That's more than enough juice to entertain you on your daily commute and get things done when you're at school or work. At home, simply recharge your Chromebook overnight and it's good to go the next day.
Lenovo 14e Chromebook - 14" - AMD A4 - 9120C - 4 GB RAM - 32 GB eMMC - UK
Chromebook
Operating System
Chrome OS - English
AMD A4 9120C / 1.6 GHz, up to 2.4 GHz / 1 MB Cache
4 GB DDR4 (provided memory is soldered)
Storage
32 GB eMMC
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
AMD Radeon R4
Keyboard
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
Up to 10 hours
Mineral grey
32.8 cm x 22.5 cm x 1.77 cm
1.48 kg
Environmental Standards
ENERGY STAR Qualified
0.38 W/kg (body) , 0.38 W/kg (limb)
Limited warranty - 1 year - pick-up and return
Chromebook
Operating System
Google Chrome OS - English
Processor / Chipset
CPU
Max Turbo Speed
2.4 GHz
Number of Cores
Dual-Core
Cache
L2 - 1 MB
64-bit Computing
RAM
4 GB (provided memory is soldered)
DDR4 SDRAM
Speed
1666 MHz
Rated Speed
833 MHz
Storage
Main Storage
32 GB eMMC - eMMC 5.1
Display
14"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
220 cd/m²
Anti-glare
Audio & Video
Graphics Processor
AMD Radeon R4 - up to
Camera
Yes - 720p
Sound
Stereo speakers, dual array microphone
Codec
DA7219
Input
Keyboard, touchpad
Keyboard Layout
Spill-resistant, buttonless touchpad, anti-pry key caps
Communications
Wireless
Wireless Controller
M.2 Card
Lithium Ion
57 Wh
Run Time
Up to 10 hours
AC Adapter
Input
Output
45 Watt
Connections & Expansion
Interfaces Details
2 x USB 3.0 , 2 x USB-C 3.0 , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD)
Mineral grey
Case Material
Polycarbonate ABS
Google H1 security chip
Theft/Intrusion Protection
USB-C power adapter
RoHS, MIL-STD 810G
Localization
1.48 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
Essential Accessories (3)
Get more from your purchase from one of our essential accessories
FFVM Lenovo 45W Standard AC Adapter (USB Type-C) Power Adapter In Stock £25.89
FFVM Lenovo 65W Standard AC Adapter USB-C In Stock £27.96
FFVM Lenovo USB-C 65W AC Adapter AC 100-240 V 65Watt for ThinkPad A275 In Stock £29.44
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
FFVM Lenovo 3Y On Site Warratny In Stock £40.07
Other bundles (1)
FFVM Lenovo ThinkPad USB3.0 to Ethernet Adapter In Stock £16.01
