Lenovo ThinkPad Yoga 11e Chromebook (1st Gen) Celeron N2940 11.6" 4GB 16GB eMMC Google Chrome OS
Quicklinx: BMN2WS00 Mfr#: 20DU000AUK
  • Celeron
  • Bluetooth 4.0
  • IEEE 802.11n
Coping with the demands of school life takes an especially robust and durable device. That's where the Lenovo ThinkPad 11e comes in - because it's specifically designed to cope with the rough and tumble of school use.
This 11.6" laptop features a rubber bumper around its top cover for absorbing the impact of side bumps. Its ultra-durable hinges and brackets are strong enough to last 50,000 cycles and the LCD panel is protected by both a stronger bezel and a reinforced rear panel.
The ThinkPad 11e is powered by a 1.83GHz Intel Celeron processor and features 4GB of RAM with 16GB of storage space. Its battery life of up to eight hours provides plenty of time to get those important tasks done.
It also comes equipped with all the features and software required for a rewarding and effective digital learning experience, as well as crisp audio and quick data transfer capability thanks to USB 3.0 - 10 times faster than previous USB technologies.
  • Rugged construction
    A rubber bumper around the top cover absorbs the force of side bumps. The corners are stronger, to reduce damage when dropped at an angle.
  • Integrated webcam
    The webcam with face tracking, plus dual digital-array microphones, will help you enjoy web conferences or online video chats like you're really there.
  • Powered USB port
    Enjoy the benefits of an always-on port, charging your USB devices without having to turn on your laptop.
  • HDMI output
    For easy connection to a television or other display.
Lenovo ThinkPad Yoga 11e Chromebook (1st Gen) - 11.6" - Intel Celeron - N2940 - 4 GB RAM - 16 GB eMMC - UK
Chromebook - flip design
Operating System
Chrome OS
Intel Celeron N2940 / 1.83 GHz, up to 2.25 GHz / 2 MB Cache
4 GB DDR3L (provided memory is soldered)
Storage
16 GB eMMC
Display
11.6" LED backlight touchscreen 1366 x 768 / HD
Graphics
Intel HD Graphics
Keyboard
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac
4-cell - up to 8 hours
Security
Trusted Platform Module (TPM 1.2) Security Chip
Graphite black
30 cm x 21.6 cm x 2.29 cm
1.5 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year - pick-up and return
Operating System
Google Chrome OS
Processor / Chipset
CPU
Max Turbo Speed
2.25 GHz
Number of Cores
Quad-Core
Cache
2 MB
64-bit Computing
Integrated memory controller, Intel Burst Technology
RAM
4 GB (provided memory is soldered)
DDR3L SDRAM
Speed
1333 MHz
Storage
Main Storage
16 GB eMMC
Display
11.6" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (10-point multi-touch)
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Audio & Video
Graphics Processor
Intel HD Graphics
Camera
Yes - 720p
Sound
Stereo speakers, microphone
Codec
Maxim Integrated MAX98090AETL+T
High Definition Audio
Input
Keyboard, touchpad
Keyboard Layout
Volume control, multi-touch touchpad, buttonless touchpad, Chrome keyboard
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 7260 - M.2 Card
4-cell Lithium Ion
35 Wh
Run Time
Up to 8 hours
AC Adapter
Input
Output
45 Watt
Connections & Expansion
USB 3.0 , USB 2.0 , HDMI , Headphone/microphone combo jack
Memory Card Reader
4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Graphite black
Case Material
Polycarbonate, polycarbonate ABS, glass-fibre reinforced plastic
Security
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
RoHS, GREENGUARD
Localization
TopSeller
1.5 kg
Sustainability Information
ENERGY STAR Certified
