Lenovo 100e (2nd Gen) WinBook 3000 Series 3015e 11.6" 4GB 64GB eMMC Windows 10 Pro National Academic
Quicklinx: FY5SWS00 Mfr#: 82GJ0000UK#EDU
  • IEEE 802.11n
Engineered for education
If you’re looking for an affordable laptop that’s engineered specifically for students and educators, you’ll love the 100e. Its rugged build means it can withstand the rigors of the school day. Its battery lasts the entire school day. And its connectivity features make collaboration smoother than ever.
Built to take a beating – and keep going
Let’s face it: Students can be tough on electronic devices. That’s why we engineered the 100e to be durable enough to withstand even the most rough-and-tumble school day: from the bus ride to the classroom to the field trip and beyond. It passes 12 MIL-STD 810G tests, boasts reinforced ports and hinges and a rugged design, and has a spill-proof keyboard with peel-resistant keys.
A flexible camera for flexible learning
The 100e comes with an HD webcam that can rotate 180 degrees. A fun way to capture photos and videos, the camera's unique design lets you interact with those around you. And it’s great for lab environments and team activities.
Power through lessons
The 100e won’t slow you down, thanks to powerful Intel® processing, LP-DDR4 memory to boost performance and maximize power efficiency, and storage options that are fast and effiicent.
No outlet? No problem.
Fading batteries distract students and slow down learning. That’s why we engineered the 100e to last the whole school day without recharging. And its lightweight, portable profile – just 1.22 kg – means it won’t drag on-the-go students and teachers down.
Connect and collaborate
Whether you need to connect to the internet or a another device, the 100e will make it happen. Multiple ports deliver powerful and fast connectivity. And 2 x 2 AC WiFi primes it for collaboration and exploration.
Homework never looked this good
Students will spend a lot of time looking at the 11.6" screen. And thanks to its HD resolution, it'll be easy on the eyes. Reduced eye strain means they can look at it even longer. Good news and bad news, students – you can spend more time on your homework!
  • Ready for whatever life throws at it
    Teachers who say the classroom feels like a battleground, take heart - this device has military-grade durability. Built tough with rubber bumpers, reinforced ports and hinges, and mechanically-anchored keys, the 100e (2nd Gen) laptop can handle all manner of shock and awe. It's drop-resistant up to 29.5" (75cm), roughly the height of a school desk.
  • See and be seen
    With an 11.6" HD display, the built-in antiglare technology on the 100e laptop (2nd Gen) reduces eye strain - great for both teachers and students. The front-facing 720p HD camera makes collaboration simple; video-conference or chat on Skype knowing you'll be seen and heard clearly.
  • Lighten your load
    With up to 10 hours of battery life, the Lenovo 100e (2nd Gen) laptop lasts an entire school day and then some, no need to haul power cords and adapters around. Students can work a full day and take the laptop home to recharge overnight for the next day's classes.
Lenovo 100e (2nd Gen) - 11.6" - AMD 3000 Series - 3015e - 4 GB RAM - 64 GB eMMC - UK
Notebook
Operating System
Windows 10 Pro National Academic - English
AMD 3000 Series 3015e / 1.2 GHz, up to 2.3 GHz / 4 MB Cache
4 GB DDR4 (provided memory is soldered)
Storage
64 GB eMMC
Display
11.6" LED backlight 1366 x 768 / HD
Graphics
AMD Radeon Graphics
Keyboard
Integrated Webcam
802.11a/b/g/n/ac/ax, Bluetooth 5.1
Up to 10 hours
Security
Trusted Platform Module (TPM) Security Chip
29 cm x 20.4 cm x 1.99 cm
1.25 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
Limited warranty - 1 year - pick-up and return
Notebook
Operating System
Processor / Chipset
CPU
Max Turbo Speed
2.3 GHz
Number of Cores
Dual-Core
Cache
L3 - 4 MB
64-bit Computing
Integrated memory controller
RAM
4 GB (provided memory is soldered)
DDR4 SDRAM
Speed
1600 MHz
Rated Speed
800 MHz
Storage
Main Storage
64 GB eMMC - eMMC 5.1
Display
11.6" - TN
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
250 cd/m²
Anti-glare
Audio & Video
Graphics Processor
AMD Radeon Graphics - up to
Camera
Yes - 720p
Sound
Stereo speakers, microphone
Codec
Realtek ALC3287
Input
Keyboard, touchpad
Keyboard Layout
Spill-resistant, anti-pry key caps
Communications
Wireless
Wireless Controller
Intel Wi-Fi 6 AX 200 - M.2 Card
Lithium Ion
42 Wh
Run Time
Up to 10 hours
AC Adapter
Input
Output
45 Watt
Connections & Expansion
Interfaces Details
USB 3.2 Gen 1 , USB 3.2 Gen 1 (Always On) , USB-C 3.2 Gen 1 (supports DisplayPort 1.4 Alt Mode) (Power Delivery) , Headphone/microphone combo jack , HDMI
Memory Card Reader
Yes (microSD)
Case Material
Polycarbonate ABS
Security
Administrator password, power-on password, MIL-STD-810G tested
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
USB-C power adapter
RoHS, Energy-Related Products (ErP) Lot 3
Localization
1.25 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
FY5S Lenovo 45W Standard AC Adapter (USB Type-C) Power Adapter In Stock £25.72
FY5S Lenovo 65W Standard AC Adapter USB-C In Stock £28.46
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
FY5S Lenovo 3Y On Site Warratny In Stock £46.57
Other bundles (6)
FY5S Lenovo USB Soundbar for Display In Stock £29.96
FY5S Lenovo 2m HDMI Cable In Stock £16.98
FY5S Lenovo ThinkPad USB3.0 to Ethernet Adapter In Stock £16.02
FY5S Lenovo ThinkVision T27q-20 27" 2560x1440 4ms HDMI DisplayPort IPS LED Monitor In Stock £312.36
FY5S Lenovo ThinkPad Bluetooth Silent Mouse - Right and Left-handed In Stock £23.79
FY5S Lenovo Thinkvision MC50 Monitor Webcam In Stock £52.44
