The Lenovo USB-C to VGA adapter turns an available USB-C port into a VGA display adapter for connecting to any display, projector or TV with a VGA input. The Lenovo USB-C to VGA adapter can be used to mirror your primary display or to extend your display to double your workspace, requiring no extra drivers to be installed.
- Lenovo - USB / VGA adapter - 24 pin USB-C to HD-15 (VGA)
- USB / VGA adapter
- 1920 x 1200 (WUXGA) support
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- 15 pin HD D-Sub (HD-15) - female
- Pricing Type
- Customer-replaceable Unit (CRU)
- Works With Chromebook
- 1-year warranty
- USB / VGA adapter
- 2.7 cm
- 22.2 cm
- 1.2 cm
- 4 g
- Connector
- Pricing Type
- 1-year warranty
