LaCie Rugged 4 TB -USB 3.0 Thunderbolt
Quicklinx: CG5ZWS00 Mfr#: STFA4000400
The LaCie Rugged RAID delivers a game-changing blend of PC and Mac compatibility, capacity, speed, mobility, and reliability. As the ultimate solution for on-the-go professionals, the LaCie Rugged adapts to the need for performance or complete data security.
  • Enhanced durability
    Designed to withstand tough conditions, the LaCie Rugged RAID features a dustproof, shock-resistant, and water-resistant build, ensuring your data stays safe even in challenging environments.
  • Flexible connectivity
    With both Thunderbolt and USB 3.0 interfaces, this external hard drive offers high-speed connectivity options for both Mac and PC users, making it a versatile choice for professionals on-the-go.
  • Optimized performance
    Factory configured with RAID 0 for high speed and capacity, and RAID 1 for data mirroring, it provides efficient performance and reliability to meet your workflow needs.
LaCie Rugged RAID STFA4000400 - hard drive - 4 TB - USB 3.0 / Thunderbolt
Hard drive - external (portable)
4 TB
Data Transfer Rate
10 Gbps (Thunderbolt) / 5.0 Gbps (USB 3.0)
Shock resistant, water resistant, RAID 1 - factory configured, RAID 0 - factory configured, dust-proof, rugged
Power Source
Included AC adapter, Thunderbolt bus
90.9 mm x 148.3 mm x 34 mm
800 g
Worldwide
4 TB
90.9 mm
148.3 mm
34 mm
800 g
Performance
Interface Transfer Rate
Max Data Transfer Rate
240 MB/s
Expansion & Connectivity
1 x USB 3.0 - 9 pin USB Type B , 1 x Thunderbolt
Power Source
Apple MacOS X 10.6 or later, Microsoft Windows Vista / 7 / 8
Protective cover
1 x Thunderbolt cable - integrated , 1 x USB 3.0 cable - USB Type A to B - external
Worldwide
