The LaCie Rugged RAID delivers a game-changing blend of PC and Mac compatibility, capacity, speed, mobility, and reliability. As the ultimate solution for on-the-go professionals, the LaCie Rugged adapts to the need for performance or complete data security.
Enhanced durability
Designed to withstand tough conditions, the LaCie Rugged RAID features a dustproof, shock-resistant, and water-resistant build, ensuring your data stays safe even in challenging environments. -
Flexible connectivity
With both Thunderbolt and USB 3.0 interfaces, this external hard drive offers high-speed connectivity options for both Mac and PC users, making it a versatile choice for professionals on-the-go. -
Optimized performance
Factory configured with RAID 0 for high speed and capacity, and RAID 1 for data mirroring, it provides efficient performance and reliability to meet your workflow needs.
- LaCie Rugged RAID STFA4000400 - hard drive - 4 TB - USB 3.0 / Thunderbolt
- Hard drive - external (portable)
- Capacity
- 4 TB
- Interface
- Data Transfer Rate
- 10 Gbps (Thunderbolt) / 5.0 Gbps (USB 3.0)
- Shock resistant, water resistant, RAID 1 - factory configured, RAID 0 - factory configured, dust-proof, rugged
- Power Source
- Included AC adapter, Thunderbolt bus
- 90.9 mm x 148.3 mm x 34 mm
- 800 g
- Localisation
- Worldwide
- Capacity
- 4 TB
- Interface
- 90.9 mm
- 148.3 mm
- 34 mm
- 800 g
Performance
- Interface Transfer Rate
- Max Data Transfer Rate
- 240 MB/s
Expansion & Connectivity
- 1 x USB 3.0 - 9 pin USB Type B , 1 x Thunderbolt
- Power Source
- OS Required
- Apple MacOS X 10.6 or later, Microsoft Windows Vista / 7 / 8
- Included Accessories
- Protective cover
- Cables Included
- 1 x Thunderbolt cable - integrated , 1 x USB 3.0 cable - USB Type A to B - external
- Localisation
- Worldwide
