LaCie Blue Eye 2 calibrator
Quicklinx: 3JWCWS00 Mfr#: 108456
An ideal complement to the LaCie 321 Monitor, the LaCie Blue Eye Pro is a single-click hardware calibration and ICC profiling solution designed for the most demanding graphics professionals. After directly adjusting your 321 Monitor to your target colorimetric settings, the LaCie Blue Eye Pro creates and activates an advanced ICC Profile. Taking advantage of a 3rd generation sensor, the LaCie blue eye colorimeter is more precise, more rapid, and more sensitive to even slight color nuances. Thanks to the Color Test module, you can easily verify the White Point Temperature, Gamma and Luminance of your monitor, and recalibrate only if necessary.
LaCie Blue Eye pro - display colour calibration kit
Display colour calibration kit
Software
Drivers & Utilities
Apple MacOS X 10.1
1-year warranty
Software Included
Drivers & Utilities
Apple MacOS X 10.1
Additional Requirements
USB port
Limited warranty - 1 year
