LaCie 8x LaCie Portable DVD/RW USB Black Creator 10
Quicklinx: 6KC2WS00 Mfr#: 301485
With the LaCie Portable DVD±RW, Design by Sam Hecht, you can easily create your own music, video and photo CDs or DVDs wherever you go. It can conveniently record to double layer DVD±R, DVD±R/RW, and CD-R/RW, and it's USB bus powered, so you only need one cable to start burning CDs and DVDs. An easy-to-use interface allows you to piece together sophisticated, full-featured DVD movies in a matter of minutes. This portable DVD±RW drive is equipped with LightScribe, an innovative technology that allows you to burn silkscreen-quality labels directly onto CDs and DVDs with a laser instead of a printer.
LaCie Portable DVD±RW Design by Sam Hecht DVD±RW (±R DL) / DVD-RAM drive - USB 2.0 - external
DVD±RW (±R DL) / DVD-RAM drive - external
USB 2.0
13.7 cm x 15.8 cm x 2.5 cm
305 g
Optical Storage
Read Speed
24x (CD) / 8x (DVD)
Write Speed
24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
CD / DVD Rewrite Speed
24x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Disc Labeling Technology
LightScribe Media Version 1.2 Coating Technology
Media Load Type
Tray
USB 2.0
13.7 cm
15.8 cm
2.5 cm
305 g
Optical Storage
Read Speed
24x (CD) / 8x (DVD)
Write Speed
Media Load Type
Tray
1 x USB 2.0
1 x USB cable - external , 1 x USB power splitter cable - external
Software Included
Roxio Easy Media Creator 10
Microsoft Windows Vista / XP
System Requirements Details
Pentium 4 RAM: 256 MB
