With the LaCie Portable DVD±RW, Design by Sam Hecht, you can easily create your own music, video and photo CDs or DVDs wherever you go. It can conveniently record to double layer DVD±R, DVD±R/RW, and CD-R/RW, and it's USB bus powered, so you only need one cable to start burning CDs and DVDs. An easy-to-use interface allows you to piece together sophisticated, full-featured DVD movies in a matter of minutes. This portable DVD±RW drive is equipped with LightScribe, an innovative technology that allows you to burn silkscreen-quality labels directly onto CDs and DVDs with a laser instead of a printer.
- LaCie Portable DVD±RW Design by Sam Hecht DVD±RW (±R DL) / DVD-RAM drive - USB 2.0 - external
- DVD±RW (±R DL) / DVD-RAM drive - external
- Interface
- USB 2.0
- 13.7 cm x 15.8 cm x 2.5 cm
- 305 g
- Optical Storage
- Read Speed
- 24x (CD) / 8x (DVD)
- Write Speed
- 24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
- CD / DVD Rewrite Speed
- 24x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
- Disc Labeling Technology
- LightScribe Media Version 1.2 Coating Technology
- Media Load Type
- Tray
- 2-year warranty
- Interface
- USB 2.0
- 13.7 cm
- 15.8 cm
- 2.5 cm
- 305 g
Optical Storage
- Read Speed
- Write Speed
- Media Load Type
- Tray
- 1 x USB 2.0
- Cables Included
- 1 x USB cable - external , 1 x USB power splitter cable - external
- Software Included
- Roxio Easy Media Creator 10
- OS Required
- Microsoft Windows Vista / XP
- System Requirements Details
- Pentium 4 RAM: 256 MB
- Limited warranty - 2 years
