LaCie 8TB Porsche Design 3.5 USB3.0 - Grey
Quicklinx: BPD2WS00 Mfr#: LAC9000604
With the P'9233's USB 3.0 interface, you'll be able to get the job done faster than ever before. Speeds up to 5Gb/s allow you to transfer a 700 MB video file in just under 7 seconds. Back up your photos, exchange audio and video files with your friends, or make sure that your important files are kept safe. With the P'9233, the possibilities are endless.
  • Accelerate your backup with USB 3.0
  • Porsche design form, LaCie function
    LaCie worked with Porsche in 2003 and it resulted in one of the most popular hard drives that's still talked about today. With the P'9233, the exclusive and timeless shape returns, with solid, reliable hardware that's sure to last for years. You can use it anywhere and be confident that you're getting superb performance.
  • Safe, strong, and aluminum
    With 5mm of solid aluminum casing surrounding the disk inside, the P'9233 keeps your data solidly protected. LaCie and porsche design worked together to combine form and function-resulting in a drive that looks great (and works great! ) no matter where you take it.
LaCie Porsche Design P'9233 - hard drive - 8 TB - USB 3.0
Hard drive - external (desktop)
8 TB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Automatic backup, Apple Time Machine compatible, LED status indicator, on/off switch
Power Source
Included AC adapter
120 mm x 190 mm x 38 mm
1 kg
8 TB
USB 3.0
120 mm
190 mm
38 mm
1 kg
Performance
Interface Transfer Rate
Expansion & Connectivity
1 x USB 3.0
Power Source
Included AC adapter
Software Included
LaCie Backup Assistant, LaCie Private-Public, LaCie Desktop Manager Eco Mode
Apple MacOS X 10.6, Apple MacOS X 10.5, Apple MacOS X Lion 10.7, Microsoft Windows Vista / XP / 7 / 8
1 x USB 3.0 cable
Enclosure Material
Aluminium
