LaCie 8TB 2big Dock Thunderbolt 3
Quicklinx: DCM6WS00 Mfr#: STGB8000400
With big capacity for a massive raw-file library and Thunderbolt 3 transfer speeds of up to 440MB/s, the LaCie 2big Dock is built to keep you creating. Designed with the creative professional in mind, the LaCie 2big Dock features Seagate IronWolf Pro drives and RAID optimization for superior power management and reliability.
  • Delivering robust performance
  • Ready, scalable
  • USB 3.0 hub
    Via the front-facing hub, charge your phone or connect a shuttle drive or digital camera to offload footage or files.
  • It's the heartbeat of your workflow
    A workflow should do just that - flow. The LaCie 2big Dock simplifies and centralizes your desktop by connecting your laptop to all of your peripherals via a single cable.
LaCie 2big Dock Thunderbolt 3 - hard drive array
Hard drive array
Total Array Capacity
8 TB
Thunderbolt 3, USB 3.1
2 (installed) / 2 (max)
Supported Drives
SATA-600
Worldwide
Built-in Devices
SD card reader
Storage Controller
RAID (SATA 6Gb/s) - RAID 0, 1, JBOD
Hard Drive
2 x 4 TB HDD SATA 6Gb/s Enterprise, HFS+ formatted, RAID 0 - factory configured
Windows 8 or later, Apple MacOS X 10.9 or later
11.8 cm x 9.33 cm x 21.7 cm
2.9 kg
5-year warranty
Hard drive array
Worldwide
Chassis
Built-in Devices
SD card reader
2
Supported Devices / Modules Qty
2
Supported Drives
SATA-600
Storage
8 TB
HDD Array External Interface
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
HDD
2 x 4 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Expansion Bays
2 (total) / 0 (free) x internal - 3.5"
Expansion Slots
1 (total) / 1 (free) x CompactFlash Card
2 x Thunderbolt 3 , 1 x DisplayPort , 1 x USB 3.1 , 1 x USB 3.0 - 9 pin USB Type A
Security lock slot (cable lock sold separately), aluminum enclosure, built-in cooling fan
Software Included
LaCie RAID Manager, Intego Backup Manager Pro, Genie Backup Manager Pro
External power adapter
11.8 cm
9.33 cm
21.7 cm
2.9 kg
Limited warranty - 5 years
