With the new d2, LaCie again raised the bar on the industry’s most trusted desktop storage product. Get the job done faster - on any computer - with dual Thunderbolt 2, USB 3.0, and a 6 TB 7200 RPM hard disk. Thanks to its innovative, all-aluminum unibody design, you’ll notice incredibly low vibration and operating noise. With best-in-class speed, versatility, and durability, the new LaCie d2 sets a new standard for desktop storage.
Versatility for professional environments
The new LaCie d2 combines Thunderbolt 2 and USB 3.0 interfaces to deliver the best possible speeds when connected to any late-model PC or Mac computer. Dual Thunderbolt 2 ports let you daisy chain up to six devices to a single Thunderbolt port on a computer. This means that you could connect up to five LaCie d2 plus a 4K display to an iMac computer's Thunderbolt 2 port, bringing remarkable scalability and convenience to 4K or other workflows. And since USB 3.0 and Thunderbolt 2 are backward compatible, you always get the absolute fastest speeds your computer allows. -
No-compromise speed for leaner workflows
Professional components yield professional speeds. The new LaCie d2 combines best-in-class interfaces with a Seagate 6 TB 7200 RPM hard disk, resulting in stunning speeds. With such speed, it's possible to store and browse a massive RAW Adobe Lightroom library with zero lag. High speeds plus industry-best capacity makes the LaCie d2 the perfect solution for storing large files and archiving projects. -
Innovative design, breakthrough durability
When recreating the industrial design of the d2, LaCie focused relentlessly on reliability and usability for professionals. -
Unibody enclosure
The casing is forged from a single sheet of aluminum, providing uncommon rigidity for long-term durability and premium quality.
- LaCie d2 Thunderbolt 2 - hard drive - 6 TB - USB 3.0 / Thunderbolt 2
- Hard drive - external (desktop)
- Capacity
- 6 TB
- Interface
- Data Transfer Rate
- 20 Gbps (Thunderbolt 2) / 5.0 Gbps (USB 3.0)
- Buffer Size
- 64 MB
- Spindle Speed
- 7200 rpm
- Security lock slot (cable lock sold separately), vibration dampening, fanless design, software encryption, 256-bit AES
- Power Source
- Included AC adapter
- 217 mm x 130 mm x 60 mm
- 1.5 kg
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Capacity
- 6 TB
- Interface
- Buffer Size
- 64 MB
- 217 mm
- 130 mm
- 60 mm
- 1.5 kg
Performance
- Interface Transfer Rate
- Max Data Transfer Rate
- 220 MB/s
- Spindle Speed
- 7200 rpm
Expansion & Connectivity
- 1 x USB 3.0 , 2 x Thunderbolt 2
- Power Source
- Power Device
- Power adapter
- Voltage Required
- AC 120/230 V (50/60 Hz)
- Software Included
- Intego Backup Assistant, LaCie Private-Public, LaCie Genie Timeline
- OS Required
- Microsoft Windows 7 / Windows 8, Apple OS X 10.8.5 Mountain Lion or later
- Cables Included
- 1 x Thunderbolt cable , 1 x USB 3.0 cable
- Enclosure Material
- Aluminium
- Limited warranty - 3 years
