The essential addition to SSD-based laptops and all-in-one computers with limited storage capacity, the latest d2 USB-C desktop drive massively expands capacity to up to 10TB for professional bandwidth intensive creative applications. The LaCie d2 Professional performs perfectly on Macs and PCs alike and also features Seagate BarraCuda Pro enterprise-class hard drives for industry-leading performance and reliability.
CROSS PLATFORM: The LaCie d2 Professional is the go-to external desktop hard drive for creatives using Mac/PC SSD-based laptops or all-in-one-computers with limited storage capacity
FAST DATA: Easily edit and archive projects with massive capacity and speeds of up to 260 MB/s
FUTURE PROOF: Seamlessly connect to USB-C, enjoy reduced noise and vibration thanks to an aluminium form factor, and get ultimate reliability and performance with BarraCuda Pro enterprise-class drives
BOUNDLESS CREATIVITY: Includes one-month membership to Adobe Creative Cloud All Apps Plan
                Robust designCrafted from aluminum, the LaCie d2 Professional external hard drive boasts a durable and sleek design that not only complements any desktop setup but also provides essential protection against daily wear and tear.
                High capacity storageWith a generous 6 TB capacity, this hard drive offers ample space for storing large files, high-resolution images, and extensive video libraries, making it an ideal solution for professionals and creatives alike.
                Efficient performanceFeaturing a USB 3.1 interface, the LaCie d2 Professional delivers fast data transfer rates of up to 240 MB/s, ensuring quick and efficient file access and backups.
                Enhanced reliabilityBundled with Seagate Rescue Data Recovery, this hard drive provides peace of mind with additional protection against data loss due to accidental damage or hardware failure.
- LaCie d2 Professional STHA6000800 - hard drive - 6 TB - USB 3.1
- Hard drive - external (desktop)
- Capacity
- 6 TB
- Interface
- USB 3.1 - USB-C
- Security lock slot (cable lock sold separately), vibration dampening, LED status indicator, Enterprise
- Power Source
- Included AC adapter
- 130 mm x 60 mm x 188.5 mm
- 1.4 kg
- Localisation
- Worldwide
- 5-year warranty
- Bundled with
- Seagate Rescue Data Recovery
- Capacity
- 6 TB
- Interface
- USB 3.1
- 130 mm
- 60 mm
- 188.5 mm
- 1.4 kg
- Bundled with
Performance
- Max Data Transfer Rate
- 240 MB/s
Expansion & Connectivity
- 1 x USB 3.1
- Power Source
- Power Device
- Power adapter
- Voltage Required
- AC 120/230 V (50/60 Hz)
- Software Included
- Adobe Creative Cloud (30 days trial)
- OS Required
- Apple macOS Sierra 10.12 or later, Windows 10 or later
- Enclosure Material
- Aluminium
- Localisation
- Worldwide
- Shipping Width
- 18 cm
- Shipping Depth
- 24 cm
- Shipping Height
- 12 cm
- Shipping Weight
- 1.6 kg
- Limited warranty - 5 years
