LaCie 5TB Rugged Thunderbolt USB-C + USB 3.0 portable extern
Quicklinx: DDVVWS00 Mfr#: STFS5000800
Rugged toughness meets USB-C compatibility and blazing-fast Thunderbolt speeds. Also featuring a tethered cable and resistance to the elements, this Rugged drive means you don't have to compromise between durability, mobility, and speed.
LaCie Rugged Thunderbolt USB-C STFS5000800 - hard drive - 5 TB - USB 3.1 Gen 1 / Thunderbolt
Hard drive - external (portable) - shock resistant, water resistant, dust-proof, crush-resistant
5 TB
USB 3.1 Gen 1 / Thunderbolt - USB-C
Shock resistant, water resistant, dust-proof, crush-resistant
Power Source
USB bus, Thunderbolt bus
90.9 mm x 148.4 mm x 34 mm
600 g
Worldwide
3-year warranty
5 TB
90.9 mm
148.4 mm
34 mm
600 g
Performance
Max Data Transfer Rate
130 MB/s
Expansion & Connectivity
1 x USB 3.1 Gen 1 - 24 pin USB-C , 1 x Thunderbolt
Power Source
Apple MacOS X 10.5 or later, Microsoft Windows 7 or later
Protective cover
1 x USB-C cable - external , 1 x USB-C to USB-A cable - external
IP54
Worldwide
Shipping Width
12 cm
Shipping Depth
18.6 cm
Shipping Height
6.7 cm
Shipping Weight
700 g
Limited warranty - 3 years
