Robust storage capacity
Equipped with a total array capacity of 20 TB and five 4 TB hard drives, the LaCie 5big Thunderbolt 2 offers ample space for large-scale data storage, making it suitable for professionals dealing with high-volume media files. -
High-speed connectivity
Featuring Thunderbolt 2 technology, this hard drive array provides high-speed data transfer rates, enhancing workflow efficiency for creative professionals by enabling quick file access and fast data backup. -
Versatile RAID support
With support for multiple RAID levels including RAID 0, RAID 1, RAID 5, RAID 6, and RAID 10, users can customize their data management strategy to balance between optimal speed, capacity, and data protection. -
Durable design
The aluminum enclosure not only gives the LaCie 5big Thunderbolt 2 a sleek, professional appearance but also acts as a heat dissipation system along with the built-in cooling fan, ensuring the drives operate at a safe temperature. -
Enhanced security
This device comes with AES-256 software encryption, providing an extra layer of security for sensitive data and protecting against unauthorized access.
- LaCie 5big Thunderbolt 2 STFC20000400 - hard drive array
- Hard drive array
- Total Array Capacity
- 20 TB
- Interface
- Thunderbolt 2
- Installed Devices / Modules Qty
- 5 (installed) / 5 (max)
- Localisation
- Canada, United States
- Storage Controller
- RAID RAID 0, 1, JBOD, 10, 5, 6
- Hard Drive
- 5 x 4 TB HDD - hot-swap
- OS Required
- Apple MacOS X 10.9 or later, Microsoft Windows 7 / Windows 8
- Power
- AC 120/230 V - 50/60 Hz
- 17.3 cm x 19.6 cm x 22 cm
- 7.6 kg
- Hard drive array
- Localisation
Chassis
- 5
- Supported Devices / Modules Qty
- 5
Storage
- 20 TB
- HDD Array External Interface
- Thunderbolt 2
Storage Controller
- RAID
- RAID Level
- RAID 0, RAID 1, JBOD, RAID 10, RAID 5, RAID 6
Hard Drive
- HDD - hot-swap
- Capacity
- 5 x 4 TB
- Spindle Speed
- 7200 rpm
- Expansion Bays
- 5 (total) / 0 (free) x hot-swap - 3.5"
- 2 x Thunderbolt
- OS Required
- Security lock slot (cable lock sold separately), built-in cooling fan, aluminum enclosure, software encryption
- Cables Included
- 1 x Thunderbolt cable
- Software Included
- Genie Backup Manager Pro, Intego Backup Manager Pro, LaCie Private-Public, LaCie RAID Manager
- AES-256
- Power Device
- External power adapter
- Voltage Required
- Power Provided
- 150 Watt
- 17.3 cm
- 19.6 cm
- 22 cm
- 7.6 kg
