Think bigger - LaCie's got you covered. With up to 48TB of capacity on your desktop, and RAID 5/6, the LaCie 6big Thunderbolt 3 lets you rein in the stampede of data from ultra high resolution cameras.
- LaCie 6big Thunderbolt 3 STFK48000400 - hard drive array
- Hard drive array
- Total Array Capacity
- 48 TB
- Interface
- USB 3.1, Thunderbolt 3
- Installed Devices / Modules Qty
- 6 (installed) / 6 (max)
- Supported Drives
- SATA
- Built-in Devices
- Led panel
- Storage Controller
- RAID RAID 0, 1, 5, 6, 10, 50
- Hard Drive
- 6 x 8 TB HDD - hot-swap - Enterprise Class Reliability, 24x7 continuous operation
- OS Required
- Apple MacOS X 10.10 or later, Windows 8 or later
- Power
- AC 120/230 V - 50/60 Hz
- 16.1 cm x 22.5 cm x 23.7 cm
- 9.9 kg
- 5-year warranty
- Hard drive array
Chassis
- Built-in Devices
- Led panel
- 6
- Supported Devices / Modules Qty
- 6
- Supported Drives
- SATA
Storage
- 48 TB
- HDD Array External Interface
Storage Controller
- RAID
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50
Hard Drive
- HDD - hot-swap
- Capacity
- 6 x 8 TB
- Spindle Speed
- 7200 rpm
- Expansion Bays
- 6 (total) / 0 (free) x hot-swap - 3.5"
- 2 x Thunderbolt 3 - 24 pin USB-C , 1 x USB 3.1 - 24 pin USB-C
- OS Required
- Audible alarm, redundant fans, e-mail notification, kensington security slot
- Cables Included
- 1 x USB-C cable , 1 x USB-C to USB-A cable
- Software Included
- Genie Backup Manager Pro, Intego Backup Manager Pro, LaCie Private-Public, LaCie RAID Manager
- AES-256
- Power Device
- Internal power supply
- Voltage Required
- Power Provided
- 250 Watt
- 16.1 cm
- 22.5 cm
- 23.7 cm
- 9.9 kg
- Limited warranty - 5 years
