LaCie 4 TB / Thunderbolt2 & USB 3.0 / 7200RPM With Cable
Quicklinx: 9VH0WS00 Mfr#: LAC9000493EK
With the new d2, LaCie again raised the bar on the industry's most trusted desktop storage product. Get the job done faster - on any computer - with dual Thunderbolt 2, USB 3.0, and a 4 TB 7200 RPM hard disk. Thanks to its innovative, all-aluminum unibody design, you'll notice incredibly low vibration and operating noise. With best-in-class speed, versatility, and durability, the new LaCie d2 sets a new standard for desktop storage.
  • Versatility for professional environments
    The new LaCie d2 combines Thunderbolt 2 and USB 3.0 interfaces to deliver the best possible speeds when connected to any late-model PC or Mac computer. Dual Thunderbolt 2 ports let you daisy chain up to six devices to a single Thunderbolt port on a computer. This means that you could connect up to five LaCie d2 plus a 4K display to an iMac computer's Thunderbolt 2 port, bringing remarkable scalability and convenience to 4K or other workflows. And since USB 3.0 and Thunderbolt 2 are backward compatible, you always get the absolute fastest speeds your computer allows.
  • No-compromise speed for leaner workflows
    Professional components yield professional speeds. The new LaCie d2 combines best-in-class interfaces with a Seagate 4 TB 7200 RPM hard disk, resulting in stunning speeds. With such speed, it's possible to store and browse a massive RAW Adobe Lightroom library with zero lag. High speeds plus industry-best capacity makes the LaCie d2 the perfect solution for storing large files and archiving projects.
  • Innovative design, breakthrough durability
    When recreating the industrial design of the d2, LaCie focused relentlessly on reliability and usability for professionals.
  • Unibody enclosure
    The casing is forged from a single sheet of aluminum, providing uncommon rigidity for long-term durability and premium quality.
LaCie d2 Thunderbolt 2 - hard drive - 4 TB - USB 3.0 / Thunderbolt 2
Hard drive - external (desktop)
4 TB
Data Transfer Rate
20 Gbps (Thunderbolt 2) / 5.0 Gbps (USB 3.0)
Buffer Size
64 MB
Spindle Speed
7200 rpm
Security lock slot (cable lock sold separately), vibration dampening, fanless design, software encryption, 256-bit AES
Power Source
Included AC adapter
217 mm x 130 mm x 60 mm
1.4 kg
Microsoft Certification
Compatible with Windows 7
3-year warranty
4 TB
Buffer Size
64 MB
217 mm
130 mm
60 mm
1.4 kg
Performance
Interface Transfer Rate
Max Data Transfer Rate
220 MB/s
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x USB 3.0 , 2 x Thunderbolt 2
Power Source
Included AC adapter
Power adapter
Software Included
Intego Backup Assistant, LaCie Private-Public, LaCie Genie Timeline
Microsoft Windows 7 / Windows 8, Apple OS X 10.8.5 Mountain Lion or later
1 x Thunderbolt cable , 1 x USB 3.0 cable
Enclosure Material
Aluminium
Limited warranty - 3 years
