LaCie 32GB Porsche Key USB 3.0
Quicklinx: 9XD7WS00 Mfr#: LAC9000501
LaCie and Porsche Design worked together to combine speed, design, and technology to create a USB key that is as beautiful as it is functional. The LaCie Porsche Design USB key is constructed with solid steel, meaning the compact design doesn't sacrifice strength. Slim size, steel strength.
The LaCie Porsche Design key's USB 3.0 interface delivers speeds up to 95 Mbps. That means much faster file transfers compared with USB 2.0 keys. And best of all, since USB 3.0 is backwards compatible with USB 2.0, there's never any worry about connectivity.
  • Secure, slim steel
  • Porsche Design form, LaCie function
    LaCie first partnered with Porsche Design to produce one of the most iconic and enduringly popular external hard drives on the market. The luxury brand and the leading technology company complement each other. Technical influence from LaCie meets the exclusive and timeless shape presented by Porsche Design.
  • Go faster with USB 3.0
LaCie Porsche Design - USB flash drive - 32 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
32 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
Software Included
Intego Backup Assistant, LaCie Private-Public, LaCie Genie Timeline
Apple MacOS X 10.6, Apple MacOS X 10.5, Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Microsoft Windows Vista / XP / 7 / 8
USB flash drive
Storage Capacity
32 GB
Hardware Encryption
256-bit AES
Interface Type
USB 3.0
Password protection, key ring loop
Software Included
53 mm
12 mm
4 mm
8 g
