LaCie and Porsche Design worked together to combine speed, design, and technology to create a USB key that is as beautiful as it is functional. The LaCie Porsche Design USB key is constructed with solid steel, meaning the compact design doesn't sacrifice strength. Slim size, steel strength.
The LaCie Porsche Design key's USB 3.0 interface delivers speeds up to 95 Mbps. That means much faster file transfers compared with USB 2.0 keys. And best of all, since USB 3.0 is backwards compatible with USB 2.0, there's never any worry about connectivity.
Secure, slim steel
LaCie and Porsche Design worked together to combine speed, design, and technology to create a USB key that is as beautiful as it is functional. The LaCie Porsche Design USB key is constructed with solid steel, meaning the compact design doesn't sacrifice strength. Slim size, steel strength. -
Porsche Design form, LaCie function
LaCie first partnered with Porsche Design to produce one of the most iconic and enduringly popular external hard drives on the market. The luxury brand and the leading technology company complement each other. Technical influence from LaCie meets the exclusive and timeless shape presented by Porsche Design. -
Go faster with USB 3.0
- LaCie Porsche Design - USB flash drive - 32 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.0
- Storage Capacity
- 32 GB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- Software Included
- Intego Backup Assistant, LaCie Private-Public, LaCie Genie Timeline
- OS Required
- Apple MacOS X 10.6, Apple MacOS X 10.5, Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Microsoft Windows Vista / XP / 7 / 8
- 2-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 32 GB
- 256-bit AES
- Interface Type
- USB 3.0
- Password protection, key ring loop
- Software Included
- OS Required
- Limited warranty - 2 years
- 53 mm
- 12 mm
- 4 mm
- 8 g
