LaCie 2TB Wireless Space NAS Ethernet / USB 2.0
Quicklinx: 752LWS00 Mfr#: 301940EK
  • IEEE 802.11n
2-Year Limited Warranty
LaCie wireless space - Design By Neil Poulton
Network-Attached Storage -- Unattached at Last
  • Back up your files wirelessly
  • Use as a router, access point, or Ethernet/Wi-Fi extender
  • UPnP, DLNA, and iTunes compatible
  • Time Machine compatible
Wireless Storage
The LaCie Wireless Space takes network-attached storage to the next level by implementing Wi-Fi technology, making it easy for you to access your files, no matter where they are in your house. It has three pre-configured modes that allow you to create a Wi-Fi access point, a Wi-Fi Ethernet extender to connect your printers or computers, or you can even use it as a Gigabit router.
Keep It All Organized
Even if you already have a Wi-Fi modem, you can use the LaCie Wireless Space as wireless storage; with capacities of 1 and 2TB, it holds all of your music, movies, and photos, helping you to access them on any computer on your home network. Backing up your files wirelessly, whether on a PC and a Mac® (and the Wireless Space is Time Machine® compatible) helps you save space and cuts down on the number of cables you have to use, saving you hassle and resources.
Replace Your Cable Box
With static and dynamic port forwarding and PPoE connections, the Wireless Space performs even better than your cable router thanks to Wi-Fi n and Gigabit Ethernet performance. You can even stream movies from the Wireless Space to any UPnP™/DLNA® compatible device, and works in tandem with iTunes®. Now, it's simple to organize your files in a central location and play them on all your devices.
Extraordinary Design
Designed exclusively for LaCie by Neil Poulton, the compact Wireless Space has a sophisticated, understated style. Its elegant, unobtrusive presence blends beautifully into your multimedia setup. This sleek network hard disk has a fashionable, mirrorpolished black finish with two unique distinguishing features--a cool, blue LED strip on its underside that creates an ambient glow, and a touch-sensitive WPS button. Its smartly engineered design
allows for natural heat dissipation and near-silent operation.
  • Capacity: 2TB
  • Interface: Gigabit Ethernet 10/100/1000 Mbits / Wi-Fi b/g/n 2.4 Ghz / 3 x USB 2.0 Host
  • Dimensions (WxDxH): 117 x 45 x 193 mm / 4.6 x 1.8 x 7.6 in.
  • Weight: 950 g / 2 lbs.
  • Warranty: 2-year limited warranty
  • Wi-Fi b/g/n, 4 Ethernet ports
  • 3 USB host ports for backup, file transfer, and expansion
  • Compact, near-silent design
  • LaCie Ethernet Agent: access shares quickly and easily
  • UPnP AV compatible
  • iTunes server
  • Supported modes (network storage available in all options): Wireless client + switch, Wireless access point + switch, No wireless + switch, Router + access point
Box Content
  • LaCie Wireless Space
  • Ethernet cable
  • External power supply
  • Utilities CD-ROM and User Manual
  • Quick Install Guide
Minimum System Requirements
  • Computer with an Ethernet network adapter
  • Latest version of Windows® XP, Windows Vista®, Windows 7 / Mac OS X 10.5, 10.6 / Linux 2.6
  • Minimum free disk space: 600MB recommended
  • Ethernet switch or router 10/100/1Gb.
  • Web browsers: Internet Explorer® 7.0, Firefox® 3.0, Safari® 3.0, or Chrome 2.0 or higher
2 TB
Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Hi-Speed USB
Resources
The following resources are available for the LaCie 2TB Wireless Space NAS Ethernet / USB 2.0
