LaCie 2TB Rugged USB-C + USB 3.0 Portable Hard Drive
Quicklinx: DDVQWS00 Mfr#: STFR2000800
Form Factor: 2.5
Capacity: 2TB
Interface: USB 3.1
12 In Stock
£145.39 ex VAT
£174.46 inc VAT
Beyond being rain, drop, and crush resistant, the LaCie Rugged USB-C is also backwards compatible with USB 3.0 and USB 2.0.
LaCie Rugged USB-C - hard drive - 2 TB - USB 3.1 Gen 1
Hard drive - external (portable)
2 TB
USB 3.1 Gen 1 - USB-C
Data Transfer Rate
5.0 Gbps (USB 3.1) / 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
Rugged pocket-sized design, rain-resistant, impact-resistant, crush-resistant
Power Source
USB bus
86 mm x 135.1 mm x 18.7 mm
100 g
2 TB
USB 3.1 Gen 1
86 mm
135.1 mm
18.7 mm
100 g
Performance
Interface Transfer Rate
Max Data Transfer Rate
130 MB/s
Expansion & Connectivity
1 x USB 3.1 Gen 1 - 24 pin USB-C
Power Source
USB bus
Software Included
LaCie Setup Assistant
Apple MacOS X 10.5 or later, Microsoft Windows 7 or later, Apple MacOS X 10.7 or later
Form Factor: 2.5
Capacity: 2TB
Interface: USB 3.1
Brand: LaCie
