Take the Rugged superpowers you've come to rely on and add the self-encrypting magic of Seagate Secure technology. What you get is a drive that's impenetrable - even when it's removed from its enclosure. LaCie Rugged Secure allows you to transfer and transport your sensitive data with no concerns for unauthorized access or intellectual property theft. All this on top of universal compatibility with USB-C, USB 3.0, and Thunderbolt 3. Not to mention the rain, drop, and crush resistance.
- LaCie Rugged Secure STFR2000403 - hard drive - 2 TB - USB 3.1 Gen 1
- Hard drive - external (portable)
- Capacity
- 2 TB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- Interface
- USB 3.1 Gen 1 - USB-C
- Shock resistant, water resistant, Seagate Secure, crush-resistant
- Power Source
- USB bus
- 86 mm x 135.1 mm x 18.7 mm
- 100 g
- Localisation
- Worldwide
- 2-year warranty
- Bundled with
- 2 years Rescue Data Recovery Service Plan
- Capacity
- 2 TB
- 256-bit AES
- Interface
- USB 3.1 Gen 1
- 86 mm
- 135.1 mm
- 18.7 mm
- 100 g
- Bundled with
Expansion & Connectivity
- 1 x USB 3.1 Gen 1 - 24 pin USB-C
- Power Source
- USB bus
- OS Required
- Apple MacOS X 10.5 or later, Microsoft Windows 7 or later
- Localisation
- Worldwide
- Limited warranty - 2 years
