LaCie 2TB Porsche Design USB-C gold
Quicklinx: DDW0WS00 Mfr#: STFD2000403
With the LaCie Porsche Design Mobile Drive's USB 3.0 interface, you'll be able to transfer files faster than ever before. Back up your photos, exchange audio and video files with your friends, or make sure that your important files are kept safe. With speeds up to 100 MB/s, the possibilities are endless.
LaCie Porsche Design P'9227 - hard drive - 2 TB - USB 3.0
Hard drive - external (portable)
2 TB
USB 3.0 - USB-C
Data Transfer Rate
5.0 Gbps (USB 3.0)
Power Source
USB bus
8.4 cm x 12.8 cm x 1 cm
190 g
2 TB
USB 3.0
8.4 cm
12.8 cm
1 cm
190 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0 - 24 pin USB-C
Power Source
USB bus
1 x USB-C to USB-A cable , 1 x USB-C cable
Enclosure Material
Aluminium
