The LaCie Porsche Design Mobile Drive welds advanced technology from LaCie with immaculate style from Porsche Design. Thanks to USB-C, this mobile drive works with any computer - the one you own and the one you might have on your wish list. And with amazing transfer speeds, you can drag and drop files and perform backups quickly.
USB-C support
Thanks to USB-C, this mobile drive works with any computer - the one you own and the one you might have on your wish list. -
Fast transfer speeds
With amazing transfer speeds, you can drag and drop files and perform backups quickly. -
Enough space for the past and the future
Featuring an extra high storage capacity, this LaCie mobile drive gives you enough space to store your digital present and your future. -
Purely useful design
The drive's minimalist style reflects practical design. The all-aluminum enclosure is lightweight but also feels sturdy and substantial in your hands. Rounded corners, polished beveled edges, and a sandblast finish combine to form the amazing style.
- LaCie Porsche Design Mobile Drive - hard drive - 2 TB - USB 3.1 Gen 1
- Hard drive - external (portable)
- Capacity
- 2 TB
- Interface
- USB 3.1 Gen 1 - USB-C
- Data Transfer Rate
- 5.0 Gbps (USB 3.1) / 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
- LED access indicator
- Power Source
- USB bus
- 84 mm x 128 mm x 10 mm
- 193 g
- 2-year warranty
- Capacity
- 2 TB
- Interface
- USB 3.1 Gen 1
- 84 mm
- 128 mm
- 10 mm
- 193 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.1 Gen 1 - 24 pin USB-C
- Power Source
- USB bus
- Software Included
- LaCie Backup Assistant, LaCie Private-Public, LaCie Desktop Manager Eco Mode
- OS Required
- Microsoft Windows 7, Apple MacOS X 10.5 or later
- Cables Included
- 1 x USB-C cable - external , 1 x USB to USB-C adapter - external
- Enclosure Material
- Aluminium
- Limited warranty - 2 years
