The LaCie Fuel creates its own Wi-Fi network, just like your home router. You can even stream an HD movie to up to 3 devices simultaneously. Family road trips, long commutes, and airport layovers just got a lot better. The LaCie Fuel lets you access an enormous media library right where it looks best: on your iPad. Just install the Seagate Media app on your iPad or iPhone, and instantly you've got a terabyte of your movies, music, and photos at your fingertips. This is how your files were meant to be browsed - with cover art for music and movies, and stunning thumbnails for photos. You can even browse according to content type, which lets you see all your movies, or music, or photos, in one place.
Play longer
Never again worry about what to sync to your iPad. With 1 TB of wireless storage, the LaCie Fuel lets you store 500+ movies or thousands of photos, songs, and documents, and access them on your iPad, iPhone, or Mac. -
Doing its share
The LaCie Fuel creates its own Wi-Fi network, just like your home router. You can even stream an HD movie to up to 3 devices simultaneously. Family road trips, long commutes, and airport layovers just got a lot better. -
Tap to access
The LaCie Fuel lets you access an enormous media library right where it looks best: on your iPad. Just install the Seagate Media app on your iPad or iPhone, and instantly you've got a terabyte of your movies, music, and photos at your fingertips. This is how your files were meant to be browsed - with cover art for music and movies, and stunning thumbnails for photos. You can even browse according to content type, which lets you see all your movies, or music, or photos, in one place. -
File transfer expressway
Thanks to Wi-Fi and the Seagate media app, you can effortlessly move files from your computer or mobile device to the LaCie Fuel. Or with a few taps on the app, free up space on your iPad or iPhone by wirelessly pushing files to the LaCie Fuel. -
Go big with Airplay
Thanks to AirPlay compatibility, the LaCie Fuel lets you go from mobile to massive with a single tap. Tap to use your iPad to play HD movies on your Apple TV. Or tap to use your iPhone to play music on your AirPlay-compatible speakers. Or tap to play a slideshow of your Instagram photos on your HDTV. With AirPlay and the LaCie Fuel, it's incredibly easy to go big.
- LaCie Fuel - network drive - 2 TB
- Network drive
- Host Connectivity
- USB 3.0 / 802.11b/g/n
- Total Storage Capacity
- 2 TB
- 11.5 cm x 11.5 cm x 2.3 cm
- 300 g ()
- Hard Drive
- 1 x 2 TB
- Networking
- 802.11b/g/n, USB 3.0
- System Requirements
- Apple MacOS X 10.6 or later, Apple iOS 5.1.1 or later, Microsoft Windows Vista / 7 / 8, Android 2.3 or later
- 2-year warranty
- Network drive
- Host Connectivity
- 2 TB
- 11.5 cm
- 11.5 cm
- 2.3 cm
- 300 g ()
Hard Drive
- HDD
- Capacity
- 1 x 2 TB
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, USB 3.0
- 1 x USB 3.0
- Cables Included
- 1 x USB 3.0 cable
- Power Device
- External power adapter
- Run Time (Up To)
- 10 hour(s)
- OS Required
- Limited warranty - 2 years
