With its iconic design and secure form factor, the Rugged has been popular hard drive. With the Rugged Mini, LaCie had shrunk the Rugged, and added tons of more features, making it a solid investment for on-the-go data transport.
The LaCie Rugged Mini hard disk shares features with the popular Rugged hard disk, like shock resistance, drop resistance, and a rubber sleeve for added protection. But with the Rugged Mini, it's also rain-resistant, and pressure-resistant!
Small member of the Rugged family
With its iconic design and secure form factor, the Rugged has been popular hard drive. With the Rugged Mini, LaCie had shrunk the Rugged, and added tons of more features, making it a solid investment for on-the-go data transport. -
Maximum reliability
The LaCie Rugged Mini hard disk shares features with the popular Rugged hard disk, like shock resistance, drop resistance, and a rubber sleeve for added protection. But with the Rugged Mini, it's also rain-resistant, and pressure-resistant! -
The speed of USB 3.0
With the Rugged Mini, you've got the speed of USB 3.0, and full backward compatibility with USB 2.0, meaning that you can use it on almost any computer.
 - LaCie Rugged Mini - hard drive - 1 TB - USB 3.0
 - Hard drive - external (portable)
- Capacity
 - 1 TB
- Interface
 - USB 3.0
- Data Transfer Rate
 - 5.0 Gbps (USB 3.0)
- Spindle Speed
 - 5400 rpm
 - Shock resistant, pressure-proof, rugged, rain-resistant
- Power Source
 - USB bus
 - 8.6 cm x 13.5 cm x 1.9 cm
 - 240 g
- Microsoft Certification
 - Compatible with Windows 7
 - 2-year warranty
- Capacity
 - 1 TB
- Interface
 - USB 3.0
 - 8.6 cm
 - 13.5 cm
 - 1.9 cm
 - 240 g
Performance
- Interface Transfer Rate
- Spindle Speed
 - 5400 rpm
Expansion & Connectivity
 - 1 x USB 3.0
- Power Source
 - USB bus
- Software Included
 - LaCie Backup Assistant
- OS Required
 - Apple MacOS X 10.6, Microsoft Windows Vista / 2000 / XP, Apple MacOS X 10.5
 - Limited warranty - 2 years
