LaCie 1TB Porsche Design P'9220 USB 3.0 2.5" Mobile Drive
Quicklinx: 7M6GWS00 Mfr#: LAC302000
The Ultimate Blend of Design and Performance
The LaCie Porsche Design P'9220 mobile hard drive is more than just a place to store your files-it's a collaboration between one of the most renowned design firms in the world and LaCie. With the P'9220, we've combined speed, design, and technology to result in a different breed of mobile drive.
Porsche Design Form, LaCie Function
LaCie first partnered with Porsche Design in 2003 to produce one of the most iconic and enduringly popular external hard drives on the market. Since then the two companies have worked closely to create products that blend flawless functionality and pure design. The luxury brand and the leading technology company complement each other, with technical influence from LaCie, together with an exclusive and timeless shape presented by Porsche Design.
Accelerate Your Backup with USB 3.0
With the P'9220's USB 3.0 interface, you'll be able to transfer files faster than ever before-a 700MB video file in just under 7 seconds! You can back up your photos, exchange audio and video files with your friends, or make sure that your important files are kept safe. With the speed of USB 3.0, the possibilities are endless. And with capacities up to 1TB, you've got the storage capacity to hold all of your files.
Safe, Strong, and Aluminum
Safe, Strong, and Aluminum Porsche Design is known worldwide for their sophisticated, timeless creations, and the P'9220 is no exception. With 3mm of strong aluminum casing surrounding the drive inside, you can be sure that your data is solidly protected. LaCie and Porsche Design worked together to combine form and function-resulting in a mobile drive that looks great (and works great)-no matter where you take it.
User-friendly Software Suite Included
  • Automatic Backup: Easy setup and automatic worry-free backup for both PC and Mac computers.
  • Password Protection: With LaCie Private-Public software built-in, it's easy to make sure that your files are secure and protected, no matter where you go.
  • Secure Online Storage: 10GB of Wuala Online Storage included for one year to securely store and share your data online.
  • 40% Energy Savings: Automatic Eco mode lowers the power consumption by up to 40% when not in use, increasing the battery life of your notebook or laptop.
  • Capacity: 1TB
  • Interface : USB 3.0 port (USB 2.0-compatible)
  • Interface Transfer Rate : USB 3.0 : up to 5Gb/s
  • USB 2.0 : up to 480Mb/s
  • Size : 71 x 130 x 18 mm / 2.8 x 5.1 x 0.7 in.
  • Weight : 270 g / 9.5 oz.
  • System Requirements : Computer with a USB 2.0 or USB 3.0 port**
  • Latest version of Windows® XP, Windows Vista®, Windows 7 / Mac OS X 10.5, 10.6
  • Check www.lacie.com/usb3mac for USB 3.0 Mac compatibility
  • Minimum free disk space: 600MB recommended
  • Box Content : LaCie Porsche Design P'9220
  • USB 3.0 cable (USB 2.0-compatible)
  • Quick Install Guide
  • Complete Software Suite:
  • LaCie Private-Public, Backup Assistant, Eco Mode*, Wuala
  • Comments : *1TB (Terabyte) = 1000GB. 1 GB = 1,000,000,000 bytes. Total accessible capacity varies depending upon operating environment (typically 5-10% less).
  • ** For optimal performance, the drive must be connected to a USB 3.0 host port. Calculations are based on average write time. Transfer rates vary slightly from one drive to another.
  • *Up to 40% energy savings with automatic standby (1W vs. 1.7W). May vary from one drive to another.
  • Warranty : 2-Year Limited Warranty
  • The ultimate blend of design and performance
    The LaCie Porsche Design P'9220 mobile hard drive is more than just a place to store your files. With the P'9220, people have combined speed, design, and technology to result in a different breed of mobile drive.
  • Accelerate your backup with USB 3.0
    With the P'9220's USB 3.0 interface, you'll be able to transfer files faster than ever before! You can back up your photos, exchange audio and video files with your friends, or make sure that your important files are kept safe. With the speed of USB 3.0, the possibilities are endless.
  • Safe, strong, and aluminum
    Safe, strong, and aluminum Porsche Design is known worldwide for their sophisticated, timeless creations, and the P'9220 is no exception. With strong aluminum casing surrounding the drive inside, you can be sure that your data is solidly protected. LaCie and Porsche Design worked together to combine form and function-resulting in a mobile drive that looks great - no matter where you take it.
LaCie Porsche Design P'9220 - hard drive - 1 TB - USB 3.0
Hard drive - external (portable)
1 TB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Password authentication, automatic backup
Power Source
USB bus
7.7 cm x 13 cm x 1.8 cm
260 g
1 TB
USB 3.0
7.7 cm
13 cm
1.8 cm
260 g
Performance
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0
Power Source
USB bus
Software Included
LaCie Backup Assistant, LaCie Private-Public
Apple MacOS X 10.6, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5
1 x USB 3.0 cable - external
