LaCie 1TB Porsche Design 2.5" USB-C Portable Hard Drive
CLEARANCE!
Clearance
Limited Time Offer
Quicklinx: D81FWS00 Mfr#: STFD1000400
The LaCie Porsche Design Mobile Drive welds advanced technology from LaCie with immaculate style from Porsche Design. Thanks to USB-C, this mobile drive works with any computer - the one you own and the one you might have on your wish list. And with amazing transfer speeds, you can drag and drop files and perform backups quickly.
  • USB-C support
  • Fast transfer speeds
    With amazing transfer speeds, you can drag and drop files and perform backups quickly.
  • Enough space for the past and the future
    Featuring an extra high storage capacity, this LaCie mobile drive gives you enough space to store your digital present and your future.
  • Purely useful design
    The drive's minimalist style reflects practical design. The all-aluminum enclosure is lightweight but also feels sturdy and substantial in your hands. Rounded corners, polished beveled edges, and a sandblast finish combine to form the amazing style.
LaCie Porsche Design Mobile Drive - hard drive - 1 TB - USB 3.1 Gen 1
Hard drive - external (portable)
1 TB
USB 3.1 Gen 1 - USB-C
Data Transfer Rate
5.0 Gbps (USB 3.1) / 5.0 Gbps (USB 3.0) / 480 Mbps (USB 2.0)
LED access indicator
Power Source
USB bus
84 mm x 128 mm x 10 mm
193 g
1 TB
USB 3.1 Gen 1
84 mm
128 mm
10 mm
193 g
Performance
Interface Transfer Rate
Expansion & Connectivity
1 x USB 3.1 Gen 1 - 24 pin USB-C
Power Source
USB bus
Software Included
LaCie Backup Assistant, LaCie Private-Public, LaCie Desktop Manager Eco Mode
Microsoft Windows 7, Apple MacOS X 10.5 or later
1 x USB-C cable - external , 1 x USB to USB-C adapter - external
Enclosure Material
Aluminium
