LaCie 1TB d2 Quadra V2.1 7200RPM eSATA/USB/FW400/800
Quicklinx: 5FJNWS00 Mfr#: 301442EK
Fully loaded with all the best interfaces - eSATA 3Gbits, FireWire 800, FireWire 400 and USB 2.0 - this all-in-one professional hard disk offers universal connectivity for PC and Mac users. For easy setup, the LaCie Setup Assistant helps format according to your needs. The unique, fanless aluminum heat sink design with 60 % more surface area for heat dissipation keeps it quiet and safe. With the LaCie Shortcut Button, easily launch any application in one push. Perfect for digital content creation, audio / video editing, DVD authoring, and web animation, etc., the d2 Quadra can handle multiple demanding professional tasks. It can be daisy-chained via FireWire or connected to your DV camera and is even bootable in FireWire for Mac and in eSATA for Mac / PC.
  • Versatile connectivity
    Equipped with a range of interfaces including FireWire 800, FireWire, USB 2.0, and eSATA-300, the LaCie d2 Quadra Hard Disk offers flexible connection options for both Mac and PC users, ensuring compatibility with a variety of setups and devices.
  • High-speed performance
    With a maximum data transfer rate of 115 MB/s through the Serial ATA interface and a spindle speed of 7200 rpm, this external hard drive is designed to deliver rapid file access and transfer speeds, making it ideal for time-sensitive projects and high-volume data tasks.
  • Generous storage capacity
    The LaCie d2 Quadra Hard Disk boasts a 1 TB capacity, providing ample space for large files, multimedia projects, and backups, all housed within a desktop form factor that complements any workspace.
LaCie d2 Quadra Hard Disk - hard drive - 1 TB - FireWire 800 / FireWire / USB 2.0 / eSATA-300
Hard drive - external (desktop)
1 TB
Data Transfer Rate
800Mbps(FireWire800)/400Mbps(FireWire)/480Mbps(Hi-Sp.USB)/3Gbps(eSATA)
Spindle Speed
7200 rpm
Power Source
Included AC adapter
17.3 cm x 16 cm x 4.4 cm
1.5 kg
3-year warranty
1 TB
17.3 cm
16 cm
4.4 cm
1.5 kg
Performance
Interface Transfer Rate
Max Data Transfer Rate
115 MB/s
Data Transfer Rate Details
Serial ATA: 115 MB/s , FireWire 800: 85 MB/s , FireWire: 40 MB/s , USB 2.0: 35 MB/s
Spindle Speed
7200 rpm
Expansion & Connectivity
1 x eSATA-300 - 7 pin external Serial ATA , 2 x FireWire 800 - 9 pin FireWire 800 , 1 x FireWire - 6 PIN FireWire , 1 x USB 2.0
Power Source
Included AC adapter
Power adapter
Software Included
Drivers & Utilities, Genie Backup Assistant, Intego Backup Assistant
Apple MacOS X 10.2.8 or later, Microsoft Windows Vista / 2000 / XP
System Requirements Details
Windows 2000/XP/Vista - 500 MHz - RAM 128 MB , MacOS X 10.2.8 or later - PowerPC G4 - 500 MHz - RAM 128 MB
Vertical stand
1 x IEEE 1394 cable - FireWire 400 (6-to-6 pin) - external , 1 x USB cable - external , 1 x eSATA cable - external , 1 x IEEE 1394b cable - FireWire 800 (9-to-9 pin) - external
Plug and Play
Limited warranty - 3 years
