Fully loaded with all the best interfaces - eSATA 3Gbits, FireWire 800, FireWire 400 and USB 2.0 - this all-in-one professional hard disk offers universal connectivity for PC and Mac users. For easy setup, the LaCie Setup Assistant helps format according to your needs. The unique, fanless aluminum heat sink design with 60 % more surface area for heat dissipation keeps it quiet and safe. With the LaCie Shortcut Button, easily launch any application in one push. Perfect for digital content creation, audio / video editing, DVD authoring, and web animation, etc., the d2 Quadra can handle multiple demanding professional tasks. It can be daisy-chained via FireWire or connected to your DV camera and is even bootable in FireWire for Mac and in eSATA for Mac / PC.
Versatile connectivity
Equipped with a range of interfaces including FireWire 800, FireWire, USB 2.0, and eSATA-300, the LaCie d2 Quadra Hard Disk offers flexible connection options for both Mac and PC users, ensuring compatibility with a variety of setups and devices. -
High-speed performance
With a maximum data transfer rate of 115 MB/s through the Serial ATA interface and a spindle speed of 7200 rpm, this external hard drive is designed to deliver rapid file access and transfer speeds, making it ideal for time-sensitive projects and high-volume data tasks. -
Generous storage capacity
The LaCie d2 Quadra Hard Disk boasts a 1 TB capacity, providing ample space for large files, multimedia projects, and backups, all housed within a desktop form factor that complements any workspace.
- LaCie d2 Quadra Hard Disk - hard drive - 1 TB - FireWire 800 / FireWire / USB 2.0 / eSATA-300
- Hard drive - external (desktop)
- Capacity
- 1 TB
- Interface
- Data Transfer Rate
- 800Mbps(FireWire800)/400Mbps(FireWire)/480Mbps(Hi-Sp.USB)/3Gbps(eSATA)
- Spindle Speed
- 7200 rpm
- Power Source
- Included AC adapter
- 17.3 cm x 16 cm x 4.4 cm
- 1.5 kg
- 3-year warranty
- Capacity
- 1 TB
- Interface
- 17.3 cm
- 16 cm
- 4.4 cm
- 1.5 kg
Performance
- Interface Transfer Rate
- Max Data Transfer Rate
- 115 MB/s
- Data Transfer Rate Details
- Serial ATA: 115 MB/s , FireWire 800: 85 MB/s , FireWire: 40 MB/s , USB 2.0: 35 MB/s
- Spindle Speed
- 7200 rpm
Expansion & Connectivity
- 1 x eSATA-300 - 7 pin external Serial ATA , 2 x FireWire 800 - 9 pin FireWire 800 , 1 x FireWire - 6 PIN FireWire , 1 x USB 2.0
- Power Source
- Power Device
- Power adapter
- Software Included
- Drivers & Utilities, Genie Backup Assistant, Intego Backup Assistant
- OS Required
- Apple MacOS X 10.2.8 or later, Microsoft Windows Vista / 2000 / XP
- System Requirements Details
- Windows 2000/XP/Vista - 500 MHz - RAM 128 MB , MacOS X 10.2.8 or later - PowerPC G4 - 500 MHz - RAM 128 MB
- Included Accessories
- Vertical stand
- Cables Included
- 1 x IEEE 1394 cable - FireWire 400 (6-to-6 pin) - external , 1 x USB cable - external , 1 x eSATA cable - external , 1 x IEEE 1394b cable - FireWire 800 (9-to-9 pin) - external
- Plug and Play
- Limited warranty - 3 years
