LaCie 12TB 2big Thunderbolt2 USB 3.0 2 Bay Desktop Raid
Quicklinx: D75MWS00 Mfr#: STEY12000400
The LaCie 2big offers game-changing speeds, compatibility, and usability for backup, file transfers, and 4K workflows. It also features Thunderbolt 2 transfer interface speeds and hardware RAID. And thanks to USB 3.0, it can be connected to nearly any computer. Its industrial design crushes the competition, making giant leaps forward for professional usability and reliability.
  • Robust storage capacity
    Equipped with a 12 TB total array capacity and dual 6 TB hard drives, the LaCie 2big Thunderbolt 2 offers ample space for large files, making it suitable for creative professionals and data-intensive tasks.
  • High-speed connectivity
    Featuring Thunderbolt 2 and USB 3.0 interfaces, this hard drive array provides fast data transfer speeds, ensuring efficient workflows and quick access to files.
  • Flexible RAID configuration
    With support for RAID 0, RAID 1, and JBOD, users can choose the optimal balance between speed and data redundancy, tailoring the storage solution to meet their specific needs.
  • Durable design
    The aluminum enclosure not only gives the LaCie 2big Thunderbolt 2 a sleek, professional appearance but also enhances its durability, making it a reliable choice for demanding work environments.
  • Enhanced security
    AES-256 compliant standards provide an added layer of security, ensuring that sensitive data stored on the device is protected against unauthorized access.
LaCie 2big Thunderbolt 2 STEY12000400 - hard drive array
Hard drive array
Total Array Capacity
12 TB
USB 3.0, Thunderbolt 2
2 (installed) / 2 (max)
Canada, United States
Storage Controller
RAID RAID 0, 1, JBOD
Hard Drive
2 x 6 TB HDD - hot-swap
Apple MacOS X 10.6 or later, Microsoft Windows 7 / Windows 8
AC 120/230 V - 50/60 Hz
10.9 cm x 13 cm x 21.7 cm
2.7 kg
Hard drive array
Chassis
2
Supported Devices / Modules Qty
2
Storage
12 TB
HDD Array External Interface
Storage Controller
RAID
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
HDD - hot-swap
2 x 6 TB
Spindle Speed
7200 rpm
Expansion Bays
2 (total) / 0 (free) x hot-swap
2 x Thunderbolt 2 , 1 x USB 3.0
Security lock slot (cable lock sold separately), aluminum enclosure
1 x Thunderbolt cable , 1 x USB 3.0 cable
Software Included
Genie Backup Manager Pro, Intego Backup Manager Pro, LaCie Desktop Manager, LaCie Private-Public
AES-256
External power adapter
Power Provided
60 Watt
10.9 cm
13 cm
21.7 cm
2.7 kg
