LaCie 10TB d2 Thunderbolt 3 & USB 3.1 7200 External HD
Quicklinx: DCM3WS00 Mfr#: STFY10000400
The perfect complement to SSD-based laptops and all-in-one computers, the LaCie d2 Thunderbolt 3 massively upgrades your capacity for professional bandwidth-intensive creative applications.
  • Rapid transfer speeds
    Experience fast data transfer with interface speeds up to 40 Gbps (Thunderbolt 3) and 5 Gbps (USB 3.0), ensuring efficient workflow and reduced wait times.
  • Expansive storage capacity
    With a generous 10 TB capacity, this external hard drive meets the demands of extensive storage requirements, making it suitable for professionals and enthusiasts alike.
  • Versatile connectivity
    Equipped with both Thunderbolt 3 and USB 3.1 Gen 1 interfaces, this hard drive offers flexible connection options to both Mac and PC users, enhancing compatibility across devices.
  • Durable design
    Crafted from aluminum, the LaCie d2 Thunderbolt 3 hard drive has a robust and reliable construction that not only ensures longevity but also complements any workspace aesthetic.
  • Seamless integration
    Designed for desktop use, this external hard drive integrates seamlessly into your workspace, supported by an included AC adapter for reliable power supply.
LaCie d2 Thunderbolt 3 - hard drive - 10 TB - USB 3.1 Gen 1 / Thunderbolt 3
Hard drive - external (desktop)
10 TB
USB 3.1 Gen 1 / Thunderbolt 3 - USB-C
Data Transfer Rate
40 Gbps (Thunderbolt 3) / 5 Gbps (USB 3.0)
Enterprise
Power Source
Included AC adapter
21.7 cm x 13 cm x 6 cm
2.2 kg
5-year warranty
10 TB
Enterprise
21.7 cm
13 cm
6 cm
2.2 kg
Performance
Interface Transfer Rate
Max Data Transfer Rate
240 MB/s
Expansion & Connectivity
1 x USB 3.1 Gen 1 - 24 pin USB-C , 2 x Thunderbolt 3 - 24 pin USB-C
Power Source
Included AC adapter
Power adapter
Windows 8 or later, Apple macOS Sierra 10.12 or later
1 x USB-C to USB-A cable - external , 1 x Thunderbolt cable - external
Enclosure Material
Aluminium
Limited warranty - 5 years
