Kyocera TK-5280M Magenta Toner
Quicklinx: DJM7WS00 Mfr#: 1T02TWBNL0
£162.73 ex VAT
£195.27 inc VAT
Kyocera TK 5280M - Magenta - original - toner kit - for ECOSYS M6235cidn, M6635cidn, P6235cdn
  • Efficient printing capacity
    Designed to support a duty cycle of up to 11,000 pages, the Kyocera TK 5280M toner kit ensures consistent and reliable performance for all your printing needs. Its high capacity makes it an ideal choice for offices with regular printing demands, offering a seamless printing experience without frequent replacements.
  • High-quality laser technology
    Utilizing advanced laser printing technology, the Kyocera TK 5280M delivers crisp, clear, and precise prints every time. Whether you're printing documents, reports, or presentations, you can expect professional-grade quality that meets the demands of any task.
Kyocera TK 5280M - magenta - original - toner kit
Toner kit
Printing Technology
Laser
Printing Colour
Magenta
Yield
Up to 11000 pages
Compatible with
ECOSYS M6235cidn, M6235CIDN/KL3, M6635cidn, M6635CIDN/KL3, P6235cdn, P6235CDN/KL3
Dimensions (WxDxH) / Weight
12 cm x 32 cm x 11 cm
Consumable
Consumable Type
Toner kit
Printing Technology
Laser
Magenta
Included Qty
1-pack
Yield
Up to 11000 pages
Compatible with
Kyocera ECOSYS M6235cidn, M6235CIDN/KL3, M6635cidn, M6635CIDN/KL3, P6235cdn, P6235CDN/KL3
Brand: Kyocera
