Kyocera TK 5240Y Yellow Original Toner Cartridge
CLEARANCE!
Clearance
Price Drop
Quicklinx: CM2QWS00 Mfr#: 1T02R7ANL0
£78.83 ex VAT
£94.59 inc VAT
For optimum performance we recommend genuine toner by KYOCERA Document Solutions, which is specially designed for your printer. Toner particles of the incorrect size can lead to poor print quality with streaky grey background or ghosting on the page. KYOCERA Document Solutions toner contains ceramic cleaning beads which are essential to ensure the printer drum is clean and particle free. This is particularly important as our drums are designed to last several hundred thousand copies.
A KYOCERA original toner will either have the KYOCERA Document Solutions logo moulded into the toner cassette or the toner will have a green KYOCERA Document Solutions label on it with white writing including our logo.
Kyocera TK 5240Y - yellow - original - toner cartridge
Toner cartridge
Printing Technology
Laser
Printing Colour
Yellow
Yield
Up to 3000 pages
Compatible with
ECOSYS M5526cdn, M5526cdn/KL3, M5526cdw, M5526cdw/KL3, P5026cdn, P5026cdn/KL3, P5026cdw, P5026CDW/KL3
Consumable
Consumable Type
Toner cartridge
Printing Technology
Laser
Yellow
Included Qty
1-pack
Yield
Up to 3000 pages
Compatible with
Kyocera ECOSYS M5526cdn, M5526cdn/KL3, M5526cdw, M5526cdw/KL3, P5026cdn, P5026cdn/KL3, P5026cdw, P5026CDW/KL3
Brand: Kyocera
