Kyocera TK 5240M Magenta Original Toner Cartridge
CLEARANCE!
Clearance
Price Drop
Quicklinx: CM2NWS00 Mfr#: 1T02R7BNL0
£73.23 ex VAT
£87.87 inc VAT
For optimum performance we recommend genuine toner by KYOCERA Document Solutions, which is specially designed for your printer. Toner particles of the incorrect size can lead to poor print quality with streaky grey background or ghosting on the page. KYOCERA Document Solutions toner contains ceramic cleaning beads which are essential to ensure the printer drum is clean and particle free. This is particularly important as our drums are designed to last several hundred thousand copies.
A KYOCERA original toner will either have the KYOCERA Document Solutions logo moulded into the toner cassette or the toner will have a green KYOCERA Document Solutions label on it with white writing including our logo.
  • Efficient printing
    Designed for efficiency, the Kyocera TK 5240M toner cartridge ensures a high yield of up to 3,000 pages, minimizing the need for frequent replacements and maintaining productivity in busy office environments.
  • High-quality output
    With its advanced laser printing technology, the Kyocera TK 5240M delivers crisp, clear, and consistent prints. This original toner cartridge is engineered to work seamlessly with your Kyocera printer, providing reliable performance and high-quality results.
Kyocera TK 5240M - magenta - original - toner cartridge
Toner cartridge
Printing Technology
Laser
Printing Colour
Magenta
Yield
Up to 3000 pages
Compatible with
ECOSYS M5526cdn, M5526cdn/KL3, M5526cdw, M5526cdw/KL3, P5026cdn, P5026cdn/KL3, P5026cdw, P5026CDW/KL3
Consumable
Consumable Type
Toner cartridge
Printing Technology
Laser
Magenta
Included Qty
1-pack
Yield
Up to 3000 pages
Compatible with
Kyocera ECOSYS M5526cdn, M5526cdn/KL3, M5526cdw, M5526cdw/KL3, P5026cdn, P5026cdn/KL3, P5026cdw, P5026CDW/KL3
Brand: Kyocera
