For optimum performance we recommend genuine toner by KYOCERA Document Solutions, which is specially designed for your printer. Toner particles of the incorrect size can lead to poor print quality with streaky grey background or ghosting on the page. KYOCERA Document Solutions toner contains ceramic cleaning beads which are essential to ensure the printer drum is clean and particle free. This is particularly important as our drums are designed to last several hundred thousand copies.
A KYOCERA original toner will either have the KYOCERA Document Solutions logo moulded into the toner cassette or the toner will have a green KYOCERA Document Solutions label on it with white writing including our logo.
Compatible Printers: Kyocera ECOSYS M 5521 cdn, Kyocera ECOSYS P 5021, Kyocera ECOSYS M 5521 cdw, Kyocera ECOSYS P 5021 cdw, Kyocera ECOSYS P 5021 Series, Kyocera ECOSYS P 5021 cdn
- Kyocera TK 5230C - cyan - original - toner cartridge
- Product Type
- Toner cartridge
- Printing Technology
- Laser
- Printing Colour
- Cyan
- Yield
- Up to 2200 pages
- Compatible with
- ECOSYS M5521cdn, M5521CDN/KL3, M5521cdw, M5521cdw/KL3, P5021cdn, P5021cdn/KL2, P5021cdn/KL3, P5021cdw, P5021CDW/KL3
Consumable
- Consumable Type
- Toner cartridge
- Laser
- Cyan
- Included Qty
- 1-pack
- Yield
- Up to 2200 pages
- Compatible with
- Kyocera ECOSYS M5521cdn, M5521CDN/KL3, M5521cdw, M5521cdw/KL3, P5021cdn, P5021cdn/KL2, P5021cdn/KL3, P5021cdw, P5021CDW/KL3
