Kyocera TK-5230C Cyan Toner Cassette
Quicklinx: CNHHQE00 Mfr#: 1T02R9CNL0
£75.62 ex VAT
£90.74 inc VAT
For optimum performance we recommend genuine toner by KYOCERA Document Solutions, which is specially designed for your printer. Toner particles of the incorrect size can lead to poor print quality with streaky grey background or ghosting on the page. KYOCERA Document Solutions toner contains ceramic cleaning beads which are essential to ensure the printer drum is clean and particle free. This is particularly important as our drums are designed to last several hundred thousand copies.
A KYOCERA original toner will either have the KYOCERA Document Solutions logo moulded into the toner cassette or the toner will have a green KYOCERA Document Solutions label on it with white writing including our logo.
Compatible Printers: Kyocera ECOSYS M 5521 cdn, Kyocera ECOSYS P 5021, Kyocera ECOSYS M 5521 cdw, Kyocera ECOSYS P 5021 cdw, Kyocera ECOSYS P 5021 Series, Kyocera ECOSYS P 5021 cdn
  • Efficient printing capacity
    Designed to support a duty cycle of up to 2,200 pages, the Kyocera TK 5230C toner cartridge ensures consistent and high-quality output for all your printing needs. Its robust performance makes it an ideal choice for both home and office environments, providing reliable service over its lifespan.
  • High-quality laser technology
    Utilizing advanced laser printing technology, the Kyocera TK 5230C delivers crisp, clear, and precise prints every time. Whether you're printing documents, reports, or presentations, you can expect professional-grade results that stand out.
Kyocera TK 5230C - cyan - original - toner cartridge
Toner cartridge
Printing Technology
Laser
Printing Colour
Cyan
Yield
Up to 2200 pages
Compatible with
ECOSYS M5521cdn, M5521CDN/KL3, M5521cdw, M5521cdw/KL3, P5021cdn, P5021cdn/KL2, P5021cdn/KL3, P5021cdw, P5021CDW/KL3
Consumable
Consumable Type
Toner cartridge
Printing Technology
Laser
Cyan
Included Qty
1-pack
Yield
Up to 2200 pages
Compatible with
Kyocera ECOSYS M5521cdn, M5521CDN/KL3, M5521cdw, M5521cdw/KL3, P5021cdn, P5021cdn/KL2, P5021cdn/KL3, P5021cdw, P5021CDW/KL3
Brand: Kyocera
