KYOCERA PF-1100. Type: Paper tray, Maximum capacity: 250 sheets, Supported media weight(s): 60 - 163 g/m². Media types supported: A4, A5, A6. Width: 375 mm, Depth: 390 mm, Height: 100 mm
Versatile media handling
Supports a wide range of media sizes including A4, A5, A6, B5, and Legal, ensuring flexibility in printing needs. -
Enhanced productivity
Equipped with a total media capacity of 250 sheets, this media tray / feeder minimizes the need for frequent reloads, boosting efficiency in high-volume printing environments.
- Kyocera PF 1100 - media tray / feeder - 250 sheets
- Product Type
- Media tray / feeder
- Total Media Capacity
- 250 sheets
- Number of Media Trays
- 1
- 37.5 cm x 39.3 cm x 10 cm
- Media Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
- Designed For
- ECOSYS M2040dn, M2040dn/KL3, M2135dn, M2135dn/KL3, M2540dn, M2540dn/KL3, M2540dw, M2635dn, M2635dn/KL3, M2635dw, M2640idw, M2640idw/KL3, M2735dw, M2735dw/KL3, P2040dn, P2040dn/KL2, P2040DN/KL3, P2040dw, P2040dw/KL2, P2040DW/KL3, P2235dn, P2235DN/KL3, P2235dw, P2235dw/KL2, P2235DW/KL3
- Product Type
- 250 sheets
- 1
- Media Sizes
- 37.5 cm - 39.3 cm - 10 cm
- Designed For
- Kyocera ECOSYS M2040dn, M2040dn/KL3, M2135dn, M2135dn/KL3, M2540dn, M2540dn/KL3, M2540dw, M2635dn, M2635dn/KL3, M2635dw, M2640idw, M2640idw/KL3, M2735dw, M2735dw/KL3, P2040dn, P2040dn/KL2, P2040DN/KL3, P2040dw, P2040dw/KL2, P2040DW/KL3, P2235dn, P2235DN/KL3, P2235dw, P2235dw/KL2, P2235DW/KL3
