Kyocera M2640IDW A4 Mono Laser Multifunction Printer
Quicklinx: CMSYWS00 Mfr#: 1102S53Nl0
Functionality: Printer, Copier, Scanner, Fax
Output Type: Monochrome
Wireless Capability: Wireless
Technology: Laser
£580.29 ex VAT
£696.34 inc VAT
A big leap forward in productivity: The ECOSYS M2640idw marks the very best of the ECOSYS series, combining outstanding performance with a vast variety of features. It is remarkably fast in every aspect and has a very low TCO. It connects with almost all smartphones, supports Wi-Fi Direct and can be controlled intuitively from a 4.3 inch touch panel.
But what really sets the ECOSYS M2640idw apart is its HyPAS option. The HyPAS platform allows you to utilize business-specific applications that will further optimize your workflow. All this makes for a truly great office all-rounder that's ready for even the toughest challenges you place in its path.
  • Up to 40 pages per minute in A4
  • Time to first copy and first print 6.4 sec.
  • HyPAS solution platform (as an option) enables powerful customisations
  • 4.3 inch (10.9 cm) touchscreen for improved usability
  • Dual scan document processor supporting A6 originals
  • Wi-Fi and Wi-Fi Direct supporting AirPrint, Mopria, KYOCERA Mobile Print
  • Print, copy, colour scan and fax functionality as standard
  • Compact design with low-noise printing
  • Exceptionally low printing costs in its class
The M2640idw marks the very best of Kyocera's new ECOSYS series, combining outstanding performance with a vast array of features. It connects with almost all smartphones, supports Wi-Fi Direct** and can be controlled intuitively from a 4.3 inch touch panel. But what really sets the M2640idw apart is its HyPAS operating system that enables you to utilise business-specific applications that will further optimise your workflow.
*Please note: An SD card and a memory upgrade is needed to enable the HyPAS platform to work
  • Efficient connectivity
    With a wide range of connectivity options including Gigabit Ethernet, USB 2.0, USB host, and Wi-Fi, along with AirPrint capability, this device ensures seamless integration into any work environment.
  • Advanced scanning and copying
    Boasts automatic duplexing for both scanning and copying, enhancing productivity and efficiency. With exposure modes tailored for text, photos, and maps, it delivers optimal results for various document types.
  • High-capacity handling
    Designed to meet the demands of busy offices, it features a 50-sheet Automatic Document Feeder (ADF), supports up to 850 sheets with its max media capacity, and accommodates a wide range of media sizes and types.
  • Eco-friendly operation
    ENERGY STAR certified, this model exemplifies commitment to environmentally sustainable printing solutions without compromising on performance.
  • Robust printing and fax capabilities
    Offers monochrome laser printing with a high resolution of 1200 DPI and a fast first print out time of 6.4 sec, alongside versatile fax capabilities with multiple data compression systems for efficient document transmission.
Kyocera ECOSYS M2640idw - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
50000 pages
Max Printing Speed
Up to 40 ppm
Max Printing Resolution
Up to 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
406 x 391 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
Scanning
600 x 600 dpi
Display
4.3"
Original Size
100 x 148 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper
Standard Media Capacity
350 sheets
Max Media Capacity
850 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB host, Wi-Fi
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network, HyPAS (Hybrid Platform for Advanced Solutions), Kyocera ECOSYS Technology, scan to FTP, scan to SMB, scan to USB host
AC 230 V (50/60Hz)
41.7 cm x 41.2 cm x 43.7 cm
19 kg
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Laser - monochrome
50000 pages
Display Diagonal Size
4.3"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
512 MB
Max Supported Memory
1.5 GB
Supported Flash Memory
SD Memory Card
Copying
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Control
Manual
Exposure Modes
Text and photo, text / photo / map
Automatic Duplexing
Copying Features
2 on 1, 4 on 1, ID Card Copy, Multiple Copy, blank page skipping, electronic sorting
Printing
Up to 1200 dpi
Max Printing Speed
Up to 40 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, KPDL3, PCL 6 (XL), PDF, XPS, PRESCRIBE IIc
Automatic Duplexing
First Print Out Time B/W
6.4 sec
Colour Management Features
Mopria
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Resolutions
Fax Machine Features
Fax polling, Duplex Fax
Document & Media Handling
Min Original Size
100 x 148 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
70 x 148 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Media Thickness Range
Up to 0.11 mm
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
350 sheets
Max Media Capacity
850 sheets
50 sheets
150 sheets
Input tray - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 100 sheets size: 70 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , ADF - 50 sheets size: 100 x 148 mm - Legal (216 x 356 mm) weight: 50 g/m² - 160 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 40 ppm (A4) - B/W , Scanning: up to 40 ipm (A4) - B/W (300 dpi) , Scanning: up to 23 ipm (A4) - colour (300 dpi) , Scanning: up to 32 ppm (A4) - B/W duplex (300 dpi) , Scanning: up to 16 ipm (A4) - colour duplex (300 dpi)
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
LDAP
Operating System Support
UNIX, Linux, Apple Mac OS X 10.5 or later, MS Windows
AC 230 V (50/60Hz)
661 Watt
Power Consumption Standby
21 Watt
Power Consumption Sleep
1 Watt
Warm-Up Time
17 sec
First Copy Out Time B/W
6.4 sec
Consumables Included
1 x toner cartridge (black) - up to 3600 pages
TUV, ISO 9001, GS, ISO 14001, ISO 7779, ISO/IEC 19752
ENERGY STAR Certified
41.7 cm
41.2 cm
43.7 cm
19 kg
Sound Emission
48.3 dBA (operating)
Ink (1)
CMSY Kyocera TK 1170 Black Original Toner Cartridge In Stock £76.36
Other bundles (1)
CMSY Kyocera PF-1100 250 Sheet Paper Feeder In Stock £169.97
Functionality: Copier
Functionality: Scanner
Functionality: Fax
Technology: Laser
Max Print Speed: 40ppm
Max Paper Size: A4 (210 x 297 mm)
Brand: Kyocera
Price Range Ex VAT: £500 - £750
