Kyocera FS1320MFP A4 Mono Laser Multifunction Printer
Quicklinx: C5YHWS00 Mfr#: 1102M53NLV
Functionality: Fax, Copier, Printer, Scanner
Output Type: Monochrome
Wireless Capability: Wired
Technology: Laser
£109.15 ex VAT
£130.98 inc VAT
The FS-1320MFP is designed for easy operation, low noise and compact size. It focus on essential functionalities, including print, copy, scan and fax capabilities as standard, which makes them ideally suited for personal, home office and small business users.
  • The Kyocera NetViewer
    The Kyocera NetViewer enables complete monitoring and control of all ECOSYS printers and digital Kyocera multifunction units from any Windows PC and thus provides ideal network administration. It also supports the standardized SNMP protocol.
  • Status monitor and command center
    The status monitor shows the current printers condition and gives direct access to the command center for the modification of settings that are not contained in the drivers.
Kyocera FS-1320MFP - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
10000 pages
Recommended Monthly Volume
1500 pages
Max Copying Speed
Up to 20 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 20 ppm
Max Printing Resolution
Up to 1800 x 600 dpi
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR
Scanning
600 x 600 dpi
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
40 sheets
Media Size
70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper
Standard Media Capacity
250 sheets
Output Trays Capacity
100 sheets
Connection Availability
USB 2.0
AC 230 V (50/60Hz)
39 cm x 36.1 cm x 36.2 cm
9.7 kg
Environmental Standards
ENERGY STAR Qualified, Blue Angel
Fax Type
Plain paper
Printing Technology
Laser - monochrome
10000 pages
1500 pages
USB 2.0
Standard Memory
64 MB
Copying
Max Copying Speed
Up to 20 ppm
Up to 600 x 600 dpi
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Exposure Modes
Text, photo, text and photo
Copying Features
2 on 1, 4 on 1, ID Card Copy
Printing
Max Printing Speed
Up to 20 ppm
First Print Out Time B/W
8.5 sec
Scanning
Optical Resolution
600 x 600 dpi
Grayscale Depth
8-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR
Fax Machine Features
One-Touch Dialing
3 station(s)
Broadcast Transmission
Document & Media Handling
Max Original Size
Original Type
Sheets
40 sheets
Min Media Size
70 x 148 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Plain paper
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
250 sheets
100 sheets
Input tray - 250 sheets size: 70 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , ADF - 40 sheets size: 140 x 210 mm - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , Output tray - 100 sheets
Speed Details
Printing: up to 20 ppm (A4) - B/W , Copying: up to 20 ppm (A4) - B/W , Scanning: up to 18 ipm (A4) - B/W , Scanning: up to 6 ipm (A4) - colour
1 x USB 2.0 - 4 pin USB Type B
Operating System Support
MS Windows XP, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Windows 8
AC 230 V (50/60Hz)
307 Watt
Power Consumption Standby
7 Watt
Power Consumption Sleep
3 Watt
Warm-Up Time
28 sec
First Copy Out Time B/W
14 sec
Consumables Included
1 x toner cartridge (black) - up to 700 pages
TUV GS, ISO 7779
ENERGY STAR Certified
Blue Angel Compliant
39 cm
36.1 cm
36.2 cm
9.7 kg
Sound Emission
28 dBA (idle) / 50 dBA (operating)
C5YH Kyocera TK-1115 TONER FOR FS-1041/1220/1320 1.6K In Stock £56.42
Functionality: Fax
Functionality: Copier
Functionality: Printer
Functionality: Scanner
Technology: Laser
Max Print Speed: 20ppm
Max Paper Size: A4 (210 x 297 mm)
Brand: Kyocera
