The FS-1320MFP is designed for easy operation, low noise and compact size. It focus on essential functionalities, including print, copy, scan and fax capabilities as standard, which makes them ideally suited for personal, home office and small business users.
The Kyocera NetViewer
The Kyocera NetViewer enables complete monitoring and control of all ECOSYS printers and digital Kyocera multifunction units from any Windows PC and thus provides ideal network administration. It also supports the standardized SNMP protocol. -
Status monitor and command center
The status monitor shows the current printers condition and gives direct access to the command center for the modification of settings that are not contained in the drivers.
- Kyocera FS-1320MFP - multifunction printer - B/W
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 10000 pages
- Recommended Monthly Volume
- 1500 pages
- Max Copying Speed
- Up to 20 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 20 ppm
- Max Printing Resolution
- Up to 1800 x 600 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR
- Scanning
- 600 x 600 dpi
- Original Size
- A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 40 sheets
- Media Size
- 70 x 148 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper
- Standard Media Capacity
- 250 sheets
- Output Trays Capacity
- 100 sheets
- Connection Availability
- Interface
- USB 2.0
- Power
- AC 230 V (50/60Hz)
- 39 cm x 36.1 cm x 36.2 cm
- 9.7 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- Fax Type
- Plain paper
- Laser - monochrome
- 10000 pages
- 1500 pages
- Interface
- USB 2.0
- Standard Memory
- 64 MB
Copying
- Max Copying Speed
- Up to 20 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Exposure Modes
- Text, photo, text and photo
- Copying Features
- 2 on 1, 4 on 1, ID Card Copy
Printing
- Up to 20 ppm
- First Print Out Time B/W
- 8.5 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Grayscale Depth
- 8-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR
Fax Machine Features
- One-Touch Dialing
- 3 station(s)
- Broadcast Transmission
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 40 sheets
- Min Media Size
- 70 x 148 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Plain paper
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
- 250 sheets
- 100 sheets
- Input tray - 250 sheets size: 70 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , ADF - 40 sheets size: 140 x 210 mm - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , Output tray - 100 sheets
- Speed Details
- Printing: up to 20 ppm (A4) - B/W , Copying: up to 20 ppm (A4) - B/W , Scanning: up to 18 ipm (A4) - B/W , Scanning: up to 6 ipm (A4) - colour
- 1 x USB 2.0 - 4 pin USB Type B
- Operating System Support
- MS Windows XP, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2, Windows 8
- Voltage Required
- 307 Watt
- Power Consumption Standby
- 7 Watt
- Power Consumption Sleep
- 3 Watt
- Warm-Up Time
- 28 sec
- First Copy Out Time B/W
- 14 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 700 pages
- TUV GS, ISO 7779
- ENERGY STAR Certified
- Blue Angel Compliant
- 39 cm
- 36.1 cm
- 36.2 cm
- 9.7 kg
- Sound Emission
- 28 dBA (idle) / 50 dBA (operating)
Kyocera TK-1115 TONER FOR FS-1041/1220/1320 1.6K | In Stock | £56.42 |
