This top end high speed, high performance printer comes with a vast array of versatile features and options. It is able to print 50 A4 color ppm in the highest quality. It has Kyocera's long life technology meaning this machine will run and run. It also has our unique toner system that keeps costs and waste to a minimum, which is good for you and for the environment.
- Kyocera FS-C8650DN - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 111 kg
- Media Size Class
- A3
- Max Media Size
- A3 (297 x 420 mm)
- Max Media Size (Custom)
- 304.8 mm x 1219 mm
- Print Speed
- Up to 27 ppm - B/W - A3 (297 x 420 mm) , Up to 25 ppm - colour - A3 (297 x 420 mm) , Up to 55 ppm - B/W - A4 (210 x 297 mm) , Up to 50 ppm - colour - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 9600 x 600 dpi
- Max Resolution (Colour)
- 9600 x 600 dpi
- Automatic Duplexing
- Interface
- USB, Gigabit LAN, USB host
- Processor
- PowerPC 750GL 750 MHz
- RAM Installed (Max)
- 1 GB (2 GB)
- Card Reader
- Hard Drive
- 160 GB
- Language Simulation
- PostScript 3, PCL 6, PRESCRIBE IIe, XPS, PDF 1.7
- Barcodes
- UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, PDF417
- Media Type
- Plain paper, banners
- Total Media Capacity
- 1150 sheets
- Media Handling
- 2x 500-sheet input trays, 150-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 225000 pages
- Networking
- Print server - Ethernet, Fast Ethernet, Gigabit Ethernet
- Printer Features
- Kyocera ECOSYS Technology
- System Requirements
- UNIX, Linux, Microsoft Windows, Apple MacOS X 10.4 or later
- Microsoft Certification
- Compatible with Windows 7
- 67.2 cm x 78.7 cm x 74.4 cm
- Printer Type
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- 9600 x 600 dpi
- 9600 x 600 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 4.9 sec
- First Print Out Time Colour
- 6.2 sec
- Fonts Included
- 93 x scalable PCL , 136 x scalable PostScript , 1 x bitmapped , 45 x barcode
- Barcodes
- Printer Features
- Media Handling
- Processor
RAM
- 1 GB / 2 GB (max)
Card Reader
- Card reader
- Supported Flash Memory Cards
- CompactFlash Card
Storage
- Hard Drive
- 160 GB
Media Handling
- Media Type
- Media Size Class
- A3
- Max Media Size
- A3 (297 x 420 mm)
- Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm)
- Media Weight
- 60 g/m² - 300 g/m²
- 1150 sheets
- Media Feeders
- 2 x automatic - 500 sheets - ARCH B (304.8 x 457.2 mm) weight: 60 g/m² - 256 g/m² , 1 x automatic - 150 sheets - 304.8 x 1219.2 mm weight: 60 g/m² - 300 g/m²
- Max Media Capacity
- 7650 sheets
- Output Trays Capacity
- 750 sheets
Duty Cycle
- 225000 pages
- Networking
- Print server
- Data Link Protocol
- TCP/IP
- Remote Management Protocol
- SNMP
- Expansion Slots
- 1 x expansion slot , Memory
- Connections
- 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 2 x direct print port - 4 pin USB Type A
- Consumables Included
- 1 x toner cartridge (black) - up to 15000 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 10000 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 10000 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 10000 pages ISO/IEC 19798
- TUV, ISO 9001, GS, ISO 14001
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 1210 Watt
- Power Consumption Stand by / Sleep
- 170 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- Sound Emission (Idle)
- 37 dBA
- Sound Emission (Operating)
- 53 dBA
- 67.2 cm
- 78.7 cm
- 74.4 cm
- 111 kg
