The ECOSYS FS-C8520MFP A3 multifunction color printer offers all the benefits of a professional document management solution for workgroups and small offices. It features the Hybrid Platform for advanced solutions, easy-to-operate touchscreen and a range of paper-handling options, all in a well-designed compact package. Cost-efficient and eco-friendly offices will appreciate Kyocera's unique ECOSYS technology which increases operating life, reduces environmental impact, cuts printing costs and ensures reliability.
Efficient connectivity
With options for Gigabit Ethernet, USB 2.0, and USB host, the FS-C8520MFP ensures seamless integration into any office network, facilitating easy sharing and efficient workflow. -
Advanced copying capabilities
Automatic duplexing, along with 2 on 1 and 4 on 1 copying features, maximizes productivity, allowing up to 999 copies at speeds of 20 ppm for both black and white and color documents. -
Versatile media handling
Supports a wide range of media sizes from A6 to A3 and weights up to 256 g/m2, including envelopes and plain paper, making it ideal for diverse printing needs. -
Eco-friendly operation
ENERGY STAR certification signifies efficient energy use, while compliance with ISO 14001 and ISO 9001 standards reflects the commitment to environmental and quality management systems. -
Comprehensive office solution
Combines the functionality of a copier, printer, and scanner with features like HyPAS technology, scan to email, and save to USB flash drive, offering a versatile tool for any office environment.
- Kyocera FS-C8520MFP - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Laser (colour)
- Max Copying Speed
- Up to 20 ppm (mono) / up to 20 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Scanning
- 600 x 600 dpi
- Original Size
- A3/Ledger (297 x 432 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 98 x 148 mm (min) - A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
- Media Type
- Envelopes, plain paper
- Standard Media Capacity
- 600 sheets
- Max Media Capacity
- 1600 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 280 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- Office Machine Features
- Save to USB flash drive, scan to e-mail, scan to network, HyPAS (Hybrid Platform for Advanced Solutions), Kyocera ECOSYS Technology
- Power
- AC 230 V (50/60Hz)
- 59 cm x 59 cm x 74.8 cm
- 80 kg
- Environmental Standards
- ENERGY STAR Qualified
- 2-year warranty (Italy - 1 year)
- Laser - colour
- Display Features
- Touch screen
- Interface
- Standard Memory
- 1.5 GB 1.5 GB
- Max Supported Memory
- 2 GB 2 GB
- Supported Flash Memory
- CompactFlash
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Modes
- Text, photo, text and photo
- Copying Features
- 2 on 1, auto tray switching, 4 on 1
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, KPDL3, PDF, XPS
- First Print Out Time B/W
- 11 sec
- First Print Out Time Colour
- 14 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 98 x 148 mm
- Max Media Size
- A3/Ledger
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 256 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), Folio (216 x 330 mm)
- 600 sheets
- 1600 sheets
- 100 sheets
- 280 sheets
- Paper cassette - 500 sheets - A3 (297 x 420 mm) weight: 60 g/m² - 256 g/m² , Bypass tray - 100 sheets - A3/Ledger (297 x 432 mm) weight: 60 g/m² - 256 g/m² , ADF - 50 sheets - A3/Ledger (297 x 432 mm) weight: 45 g/m² - 160 g/m² , Output tray - 250 sheets , Job separator tray - 30 sheets
- Speed Details
- Printing: up to 20 ppm (A4) - B/W , Printing: up to 20 ppm (A4) - colour , Copying: up to 20 ppm (A4) - B/W , Copying: up to 20 ppm (A4) - colour , Scanning: up to 40 ipm (A4) - B/W , Scanning: up to 40 ipm (A4) - colour , Printing: up to 10 ppm (A3) - B/W , Printing: up to 10 ppm (A3) - colour
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- SSL, IPsec
- Operating System Support
- UNIX, Linux, Apple MacOS X 10.4 or later, MS Windows
- Voltage Required
- 557 Watt
- Power Consumption Standby
- 121 Watt
- Power Consumption Sleep
- 0.9 Watt
- Warm-Up Time
- 55 sec
- First Copy Out Time B/W
- 11.7 sec
- First Copy Out Time Colour
- 13.6 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 3000 pages , 1 x toner cartridge (cyan) - up to 1500 pages , 1 x toner cartridge (magenta) - up to 1500 pages , 1 x toner cartridge (yellow) - up to 1500 pages
- TUV GS, ISO 9001, ISO 14001
- ENERGY STAR Certified
- Limited warranty - 2 years , Italy: limited warranty - 1 year
- 59 cm
- 59 cm
- 74.8 cm
- 80 kg
- Sound Emission
- 35 dBA (idle) / 47 dBA (operating)
