Kyocera FS-9530DN A3 Duplex Mono Printer
Quicklinx: BKRGWS00 Mfr#: 1102G13NL0
Wonderfully fast and reliable, the FS-9530DN printer also comes with a highly functional modular design that large departments need to get the entire job done. And with a print speed of 51 pages per minute in A4, the Kyocera FS-9530DN can handle large print volumes quickly and professionally.
  • Efficient printing speed
    With a printing speed of up to 51 ppm for A4 and 26 ppm for A3 documents, this workgroup printer ensures your work flows smoothly and efficiently, reducing wait times and increasing productivity.
  • Advanced connectivity options
    Equipped with Ethernet, USB, and parallel interfaces, this printer offers versatile connectivity options, making it easy to integrate into any office environment and allowing multiple users to connect seamlessly.
  • High-resolution output
    Kyocera Image Refinement 2 technology alongside a maximum resolution of 1800 x 600 DPI delivers sharp, clear, and professional monochrome prints, ensuring your documents always look their best.
  • Generous media handling
    A total media capacity of 1200 sheets, supported by a 200-sheet multipurpose tray and two 500-sheet input trays, accommodates a wide range of media sizes and types, from plain and recycled paper to labels and foil paper, offering the flexibility your office needs.
  • Eco-friendly design
    ENERGY STAR certified, this printer meets strict energy efficiency guidelines, making it an environmentally friendly choice for your office without compromising on performance or productivity.
Kyocera FS-9530DN - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
68 kg
Media Size Class
A3/Ledger
Max Media Size
A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm)
Max Media Size (Custom)
297 mm x 450 mm
Print Speed
Up to 51 ppm - B/W - A4 (210 x 297 mm) , Up to 26 ppm - B/W - A3 (297 x 420 mm)
Max Resolution (B&W)
1800 x 600 dpi
Image Enhancement Technology
Automatic Duplexing
Parallel, USB, LAN
PowerPC 750FL 600 MHz
RAM Installed (Max)
128 MB (640 MB) - DDR SDRAM - DIMM 100-PIN
Card Reader
Language Simulation
PostScript 3, PCL 6, EPSON LQ, Diablo 630, KPDL3, KC-GL, PDF, PRESCRIBE IIe, IBM ProPrinter X24e
Barcodes
UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, PDF417
Media Type
Labels, plain paper, foil paper, recycled paper
Total Media Capacity
1200 sheets
Media Handling
2x 500-sheet input trays, 200-sheet multipurpose tray
Monthly Duty Cycle (max)
300000 pages
Recommended Monthly Volume
55000 pages
Print server - Ethernet, Fast Ethernet
UNIX, Linux, Microsoft Windows, Apple MacOS X 10.2 or later, Apple MacOS 9.x or later
Microsoft Certification
Certified for Windows Vista
59.9 cm x 64.6 cm x 61.5 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Built-in Devices
Status LCD
Wired
Parallel, USB, LAN
1800 x 600 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
3.5 sec
Language Simulation
Fonts Included
136 x PostScript 3 , 80 x scalable , 1 x bitmapped , 45 x barcode
Barcodes
Media Handling
RAM
RAM Installed (Max)
128 MB / 640 MB (max)
Technology / Form Factor
Slots Qty
1
Empty Slots
1
Card Reader
Card reader
Supported Flash Memory Cards
CompactFlash Card
Media Handling
Media Type
Media Size Class
A3/Ledger
Max Media Size
297 mm x 450 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), Folio (216 x 330 mm), 297 x 450 mm, 88 x 148 mm
Media Weight
45 g/m² - 200 g/m²
1200 sheets
Media Feeders
1 x automatic - 200 sheets - 297 x 450 mm weight: 45 g/m² - 200 g/m² , 2 x automatic - 500 sheets - 297 x 432 mm weight: 60 g/m² - 105 g/m²
Max Media Capacity
4200 sheets
Output Trays Capacity
500 sheets
Duty Cycle
300000 pages
55000 pages
Print server
Expansion Bays
1 (total) / 1 (free) x internal
Expansion Slots
1 x CompactFlash Card
1 x LAN - RJ-45 , 1 x parallel - 36 PIN Centronics , 1 x USB 2.0 - 4 pin USB Type B
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
TUV, ISO 9001, GS, ISO 14001
Power supply - internal
Frequency Required
50/60 Hz
900 Watt
Power Consumption Stand by / Sleep
180 Watt
Environmental Standards
ENERGY STAR
Sound Emission (Idle)
37 dBA
Sound Emission (Operating)
56 dBA
59.9 cm
64.6 cm
61.5 cm
68 kg
