Kyocera FS-9130DN Mono Laser Printer
Quicklinx: 7J3CWS00 Mfr#: 1102GZ3NL1
With a print speed of 40 pages per minute in A4, the Kyocera FS-9130DN is ready to carry you through the heaviest of loads without slowing down. Fast, efficient and reliable, this printer also has a highly functional modular design. The paper and finishing options make it easy to fit the printer to your department's precise needs.
  • Reliability
    The FS-9130DN is certified highly reliable by BLI, completing a 100000 impression durability test with just on misfeed and no service of any kind required. Furthermore, the unit went on to produce another 100000 impressions over the course of toner yield testing with no failures.
  • Easy of network setup
    Setup and installation of the drivers was easy thanks to the auto install feature, which automatically crates the port and will have users up an running in minutes. Although installation of the KX driver requires 12 clicks of the mouse because the drivers are combines, users need only install one.
  • Print productivity
    Using the KPDL driver to produce BLI's 19-page job stream, which replicates typical office usage in a multi-user environment, the FS-9130DN's efficiency of 65.4 percent of its rated engine speed is well above average compared to ledger-size laser/LED devices tested to date.
  • Easy of use
    The FS-9130DN's control panel is well designed and easy to use, featuring a two-line, 32-character LCD and eight LEDs for ready, attention, finisher, drawer one, drawer two, drawer three and bypass.
  • Security features
    Secure print allows a user to send a print job directly to the FS-9130DN and hold it until it is release via the control panel. After it is printed the unit deletes the job from memory. Administrators can lock the control panel via the embedded web page.
  • Value
    The FS-9130DN's supplies cost per page is the lowest compared to ledger-size laser/LED devices in this speed range tested to date. In fact, it is just over 80 percent lower than the average. This much lower cost per page translates to a substantial cost saving over competitive devices throughout its lifetime.
Kyocera FS-9130DN - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
68 kg
Media Size Class
A3/Ledger
Max Media Size
A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm)
Max Media Size (Custom)
297 mm x 450 mm
Print Speed
Up to 40 ppm - B/W - A4 (210 x 297 mm) , Up to 23 ppm - B/W - A3 (297 x 420 mm) , Up to 33 ppm - B/W duplex - A4 (210 x 297 mm) , Up to 16 ppm - B/W duplex - A3 (297 x 420 mm)
Max Resolution (B&W)
1800 x 600 dpi
Image Enhancement Technology
Kyocera Image Refinement 2
Automatic Duplexing
Parallel, USB, LAN, USB host
PowerPC 750FL 600 MHz
RAM Installed (Max)
64 MB (576 MB) - DDR SDRAM - DIMM 100-PIN
Card Reader
Language Simulation
PostScript 3, PCL 6, EPSON LQ, Diablo 630, KPDL3, KC-GL, PDF, PRESCRIBE IIe, IBM ProPrinter X24e
Barcodes
PDF417
Media Type
Labels, plain paper, foil paper, recycled paper
Total Media Capacity
1200 sheets
Media Handling
2x 500-sheet input trays, 200-sheet multipurpose tray
Monthly Duty Cycle (max)
180000 pages
Recommended Monthly Volume
20000 pages
Print server - Ethernet, Fast Ethernet
UNIX, Linux, Microsoft Windows, Apple MacOS X 10.2 or later, Apple MacOS 9.x or later
Microsoft Certification
Certified for Windows Vista
(France - 1 year)
59.9 cm x 64.6 cm x 61.5 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Built-in Devices
Status LCD
Wired
1800 x 600 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
3.5 sec
Language Simulation
Fonts Included
136 x PostScript 3 , 80 x PCL , 1 x bitmapped , 45 x barcode
Barcodes
PDF417
Media Handling
RAM
RAM Installed (Max)
64 MB / 576 MB (max)
Technology / Form Factor
Slots Qty
1
Empty Slots
1
Card Reader
Card reader
Supported Flash Memory Cards
CompactFlash Card
Media Handling
Media Type
Media Size Class
A3/Ledger
Max Media Size
297 mm x 450 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), Folio (216 x 330 mm), 297 x 450 mm, 88 x 148 mm
Media Weight
45 g/m² - 200 g/m²
1200 sheets
Media Feeders
1 x automatic - 200 sheets - 297 x 450 mm weight: 45 g/m² - 200 g/m² , 2 x automatic - 500 sheets - 297 x 432 mm weight: 60 g/m² - 105 g/m²
Max Media Capacity
4200 sheets
Output Trays Capacity
500 sheets
Duty Cycle
180000 pages
20000 pages
Print server
Expansion Bays
1 (total) / 1 (free) x internal
Expansion Slots
1 x CompactFlash Card
1 x LAN - RJ-45 , 1 x parallel - 36 PIN Centronics , 1 x USB 2.0 - 4 pin USB Type B
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
TUV, ISO 9001, GS, ISO 14001
Power supply - internal
Frequency Required
50/60 Hz
710 Watt
Power Consumption Stand by / Sleep
160 Watt
Environmental Standards
ENERGY STAR
Regional Warranty Exceptions
France - 1 year
Sound Emission (Idle)
37 dBA
Sound Emission (Operating)
56 dBA
59.9 cm
64.6 cm
61.5 cm
68 kg
7J3C Kyocera Toner Kit TK-710 In Stock £142.27
